I had a 3" suspension lift(MarkMC) installed recently and all is good, even got the alignment within spec without flipping the UCA's. So today I decided to check out the 4WD which worked fine but when I started getting up to speed limit I noticed a front end shake which was not there prior to the lift, I was in rush hour traffic so could not check higher speeds but at start it is good then as I get it going it starts to shake then goes away, if I get on it I really feel it.
Any ideas as to what this may be or something not done during lift install?
Conditions were dry and hot driving on asphalt surface.
. I knew 7/16 didn't sound right lol
