LED Roof Rack Mounting DIY Option
by AA1PR » Thu Mar 05, 2015 5:46 pm
I want side illumination off the rig for camping etc with these 4 18W slim LED’s
ok my desire is to add 4 LED's to the factory roof rack channels
this works for my 2004 gmc yukon, not sure if all years are the same or for the mid size vehicles most of you have here
I discovered through online research that Fastenal Part No. (SKU): 48590 seemed to be the part I needed ~ https://www.fastenal.com/web/products/d ... ngMachine=
so I got 8 of these 4 as spares, bag of 1" fender washers & 3/4" 1/4X20 bolts
these channel nuts are tapped for 1/4X20 thread, which easily handles the weight & load of any small light like this
Parts all gathered:
I decided to have the channel nut on the bottom of course, then a washer, the mounting bracket & then another washer to finish it all off
this keeps everything very tight
I had to put the channel nut down on the outside lip of the factory channel & give a firm downwards push to get it in & you may too
once its seated it looks like this
& a wider view
now if warmer weather ever gets here I'll get these installed & wired up & report back
I'm thinking with some Yankee ingenuity you could use this for other projects off the factory channel
1966 Stevens M416 trailer too
AA1PR
by Jrgunn5150 » Fri Mar 06, 2015 8:53 am
Pretty clever!
by AA1PR » Fri Mar 06, 2015 5:59 pm
Jrgunn5150 wrote:Pretty clever!
thanks
& today I learned that they also sell these channels nut in stainless steel, I wish I knew that yesterday
AA1PR
by DirtyBacon04 » Fri Mar 06, 2015 8:24 pm
very clever. I love that superstrut hardware since I discovered it!
by Jrgunn5150 » Sat Mar 07, 2015 10:54 am
McMaster-Carr has enough weird stuff to blow your mind lol
by KE7WOX » Tue Mar 10, 2015 5:14 pm
Jrgunn5150 wrote:McMaster-Carr has enough weird stuff to blow your mind lol
And to blow a massive hole in your wallet too.
by AA1PR » Wed Mar 11, 2015 10:37 pm
today I got them all wired up, need to get some protective wire loom over them & then get my son to mount them for me
https://www.youtube.com/watch?v=YgxZoN-zzmc
AA1PR
by AA1PR » Fri Mar 13, 2015 8:44 pm
AA1PR
