Rather than just build one like the more popular roof baskets - Surco or Baja Racks, I though I'd list the reasons I needed a rack in the first place:
1. I do a lot of home improvements and projects around the house, so I need to occasionally bring lumber home. I have a 4x8 folding Harbor freight trailer, but I don't always like bring it out. The stock roof crossbars are too weak and don't offer a very good tie down anchors.
2. When we go camping or on long road trips, I found that we pack a lot of gear around my son and his car seat. I really want to have the cargo area more secure with fewer things that can fly around. Packing items up top works.
3. I only get about 14-16 MPG overall, so I'm not too worried about the rack's effect on that.
4. I'm not a big fan of roof lights (yet) but I thought I should build it to accomodate lights front and back.
Design requirements:
1. Width - I need to be able to carry a couple of 4 x 8 sheets of plywood
2. Height - I need to be able to carry 4 x 4 posts
3. Needs to be in expensive
4. It can't increase the wind noise much more - I intend to keep the rack on year round.
5. Since I'm fabricating it, it needs to be steel
6. Would like to keep the rack's weight to a minimum.
7. Light mounts 4 in the front and 2 in the back.
Materials:
3/4" EMT conduit
2 hole and one hole brackets for 3/4" conduit
Finish:
Rustoleum primer and black hammer finish spray paint
Tools:
3/4" conduit bender
Lincoln 100HD 110V wire feed welder (flux core)
wire wheels and sanding disks for my angle grinder and drill
1" hole saw for my drill press (for notching the upright pieces of the rack)
Well after wasting a couple of pieces of conduit learning how to use the bender and lot of practice welding to dial in the welder I built this:
Height: 5 1/2 inches, 3 3/4 inches between top and bottom tubes
Width: 50 inches, 48 1/4 inches between uprights
Length: 64 inches not including light mount tabs
Crossbars mounted 9-10 inches on center
Weight: I'll have to get this next time I remove it.
The closest the basket comes to the roof rails is 3/8" the closest it come to the roof itself is 1 1/4 ", so it sits pretty low. At the front and rear of the basket the top bars sits just shy of 8" off the roof (because of the curve of the roof line front to back).
I fab'd up some light mounts from some square tubing I had in the garage. 4 up front and 2 in the back. I didn't drill mounting holes yet. I'll do that when I get lights.
I used some 1x1 aluminum square tubing and some 2 hole conduit mounting brackets to fab some mounts for the rack. 4 in total. I'm not sure I like the mounts. They seem too narrow and right now there are two sets of hardware on each "foot". 1 set to mount the rack to the "foot" and a second set to mount the "foot" to the roof rails. I think I'm going to simplify this and use 1.5" wide 1/2 inch steel bar stock (scrap) using one set of hardware to both mount the rack and secure it to the rails. I did reuse some Yakima rack hardware I had they are SS threaded rectangular pieces that the allen head bolts thread into to secure the "foot" to the rails. I also added some pieces of rubber under each foot between the foot an the top of the rail. It very solid none the less. In the end though I will bolt the "feet" through the roof rails for and even more secure mount.
The wind fairing is a flat piece of Plexiglas mounted to the straight portions of the two front horizontal bars of the basket which eliminates almost all the wind noise from the rack. I used one hole conduit mounting brackets and SS hardware to secure the fairing.
I'm still painting the fairing and I'll add pictures of the rack with the fairing later.
Objectives Met? I think so.
1. Width - I need to be able to carry a couple of 4 x 8 sheets of plywood.
Without any uprights in the front or rear, plywood sheets fit just perfect. The other day I slid a full 4' X 8' sheet of 1/2" particle board up top without the fairing mounted. The board overhangs the front and back only 1.5 ft each.
2. Height - I need to be able to carry 4 x 4 posts.
With a spacing of 3 3/4 inches between the top and bottom tubes I should be able to get 4x4 posts up there. 8' posts should only over hang the front and back by 1.5' each.
Still tallying the total cost. I used about ten 10' pieces of conduit and assorted hardware. The conduit bender and the SS hardware is the most expensive. Using scrap steel and Plexiglas that's lying around the garage saves $$.
The fairing mounted to the front horizontal tubes makes the rack pretty quiet. I'm planning on making a fairing that wraps around the front curves of the basket. Tatstill in the works though.
5. Since I'm fabricating it, it needs to be steel.
The steel conduit worked great. did my grinding/sanding and welding outside with plenty of ventilation. My welding is not the best, so some of the welds are not pretty, but they are pretty solid. My welds got better as I went along.
Still have to weight the whole thing next time its off the TB. Mounting or removing only takes about 10 minutes with one person (me). The rack really isn't that heavy
7. Light mounts: 4 in the front and 2 in the back.
Using scrap square tubing notched with the 1" hole saw and formed with a bench grinder these turned out nice and are pretty sturdy. I'll drill the mount holes later when I have lights.
I'll see how this rack works for me and how well it holds up. I do have some design changes I'll make with version 2.0 if that comes to be.
