fishsticks wrote:Some of those welds look a bit porous. Are you using flux core? I find my welds look a ton better if I crank the wire speed up to 7+ at full power on 3/16". I put a HUGE bead on and then grind down what I don't want.
Exactly! If your beads on the mounts and/or hitch look like that, I wouldn't use it for pulling anything!
With flux core, you can do small circles, but you can't go back onto "less hot" weld with big circles like you can with MIG... I've had the best luck with 110 flux core by just going down the seam, slow and steady, letting the puddle "push" you along, as it gets the width that you want...
ETA: This guy is on Pirate, and if you use the code "GRIT" they are even cheaper:
http://www.roarksupply.com/4-1-2-Zircon ... pdiscs.htm Get the 60 or 80 grit ones. They are $1.89 each after the discount, and they are as good or better than the $7 ones I've gotten locally... I ordered a bunch a while back, and they really are good...
