Another take on a roof top light bar
by Jimbo121 » Wed Dec 21, 2011 5:04 pm
Ok I know its been done a hundred times but here is my current mod and how I went about mounting the light bar.
First I have to not that if you have an older TB or Envoy be careful when removing these bolts. My front passenger side was rusted to the nut that is pressed into the sheet metal which made this mod a pain in the a@*.
[color=#4000FF] some days your the predator, some days your the prey!!!
Jimbo121
by Jimbo121 » Wed Dec 21, 2011 5:07 pm
Mid way through
Jimbo121
by Gordinho80 » Wed Dec 21, 2011 6:34 pm
Am I the only one not seeing anything????
by Jimbo121 » Wed Dec 21, 2011 7:14 pm
No your not!!! We need a mobile app. Here are the pics that were supposed to be above.
using square stock I just lopped off the ends leaving a tab for the mount to the roof bar. Welded tabs for the lights and drilled the entry holes to run the wire inside the bar
No body had mounted to the front bolt yet
Jimbo121
by Jimbo121 » Wed Dec 21, 2011 7:19 pm
I wish we could attach more then three pics :facepalm:
keeps it nice and close to the roof line to eliminate wind noise
Jimbo121
by Jimbo121 » Wed Dec 21, 2011 7:24 pm
Still waiting on the other two 550s, the bar is attached to the roof with the front mounting bolt of the rack slide. it is sandwiched between two grommets to cut and vibration. Even at highway speeds it doesn't cause any noise at all.
Even my squad car roof lights caused noise at 70mph!!!!
other two 550s are en route don't know where
Jimbo121
by djthumper » Wed Dec 21, 2011 7:34 pm
Something like this is what I have been considering. I am just not that far into it yet for the lights...
by v7guy » Wed Dec 21, 2011 8:11 pm
Looks pretty alright. I like it.
Do you plan on drilling a hole or routing the wires through the door?
by Jimbo121 » Wed Dec 21, 2011 8:55 pm
Drilling a hole. Under the same area where the bar is mounted.
Jimbo121
by DirtyBacon04 » Wed Dec 21, 2011 9:07 pm
Wow! Seems easy enough to where I could do it without the supervision of Roadie... But I dont want to offend him :poke:
by gotspeed1 » Wed Dec 21, 2011 9:13 pm
^^ DON'T DO IT!!! :finger:
@OP- Looking really good. I wish I would have thought of it before I changed roof rails. That's a much simpler way to not lose a bunch of light on the roof.
gotspeed1
by Trail X » Wed Dec 21, 2011 9:58 pm
I used that same method for part of my half-roof rack. Seems to hold well, but I was a bit worried about pulling out one of those rivet nuts. I guess I could always pop a new one in.
We do have a mobile app, it's called tapatalk. :work:
We intentionally limit it to 3 pictures per post just to try to nudge people to just other photo-hosting options, like photobucket. :twisted:
About the wind noise, the TB really does do a decent job at hiding the wind noise. I barely notice any noise from my rack and tent... mainly just the occasional creaking noises.
by Mudwheelin » Wed Dec 21, 2011 11:22 pm
I took my light bar off. I posted that I couldnt get rid of the wind noise. I tried everything. But I havent givin up yet. Your light bar looks great by the way!
Build Thread:
viewtopic.php?f=25&t=2349
Mudwheelin
by Jimbo121 » Mon May 21, 2012 6:17 pm
Welding the ends shut and running the wiring inside the tube, using gromits on the wires as they exit the tube are all things that I did to limit that. I have to say I haven't had any noticeable noise.
Jimbo121
by Cody_S » Wed May 23, 2012 6:41 am
I like the idea of using those bolts, well done, looks nice :)
Cody_S
by Jimbo121 » Sat Jun 02, 2012 12:13 am
The only hiccup so far was that I used the left over flap after cutting the tubing that was too flexible. I welded another piece of 18 gauge steel in place and that is holding very well.
Jimbo121
Return to Fab Work
