New guy from St louis, MO
by kingm1989 » Thu Jan 01, 2015 10:15 pm
Hey guys been reading the forums for a while now and finally decided to post. I've got an 04 trailblazer ls 2wd i6 I don't offroad much but have alot of small trails on my property and just love the way these things look up in the air. I started with the rough country lift in the front and z71 springs in the rear. I've got a set of moog 114 springs for the front and spacers for the rear springs. I'm going to try to fit some 315/75/16s under it and I have the wheel spacers already for it. I already flipped the uca knowing I was adding to the RC lift that is on already.
kingm1989
DriveTrain: 2WD w/ Limited Slip
by SmokeyMcBlazer » Thu Jan 01, 2015 10:35 pm
welcome aboard
SmokeyMcBlazer
by Trail X » Thu Jan 01, 2015 10:48 pm
Welcome to the site. And if you have a TB, and you have a locking rear end, you have the 2WD w/ G80 option, not the limited slip option. The limited slip is really only on the SSs or you installed an aftermarket LSD yourself (referencing your profile).
by kingm1989 » Fri Jan 02, 2015 12:01 am
I must have selected it wrong when I made my profile I don't have the g80 option just a super base everything TB
kingm1989
kingm1989
by kingm1989 » Fri Jan 02, 2015 12:02 am
And here it is nowImage
kingm1989
by maricard » Fri Jan 02, 2015 9:41 am
Welcome Mark, have fun!
_____LESS IS MORE_____
Ludwig Mies van der Rohe
maricard
by HARDTRAILZ » Fri Jan 02, 2015 1:21 pm
Welcome
by ErikSS » Fri Jan 02, 2015 1:27 pm
Welcome! You will need to cut some of your fender to fit that tire. A body lift in addition to the suspension lift may also be desired. Have fun!
by Cable810 » Fri Jan 02, 2015 3:28 pm
Welcome!!
by kingm1989 » Fri Jan 02, 2015 8:35 pm
I'm putting the 114 springs on tonight and spacers in the rear. Yeah I know I'm in for some trimming I'm not a huge fan of body lifts but if that's what it takes then oh well lol. Not sure of its gonna fit in or out of my garage after tonight but we shall see.
kingm1989
by kingm1989 » Sun Jan 04, 2015 1:28 pm
Ok 114 springs on spacers in the rear and tires on and here is how it looks
kingm1989
by maricard » Sun Jan 04, 2015 2:07 pm
Great look! Have you enough clearance to move tire in any direction with this setup?
maricard
by kingm1989 » Sun Jan 04, 2015 10:37 pm
I had to do some trimming in the front and I'm thinking about extending the four link in the rear to center the rear tire it's pretty close to the back door
kingm1989
