Inline 6 engine noise??
by jhurgin » Sat Mar 29, 2014 5:31 pm
So I have read…and heard first hand unfortunately, that the inline 6 is quite a noisy engine. It's quiet as can be but once 3k miles comes around after an oil change it starts to sound a bit "rough". Is this something that others have experienced and if so does this vehicle need a bit more standard maintenance than other vehicles. any info is much appreciated. thanks in advance.
jhurgin
by navigator » Sat Mar 29, 2014 5:53 pm
I think most folks that follow the OLM get 7-10k miles on conventional oil.
I change mine about every 7500 with synthetic.
I have a little vibration at idle but no noise.
by jhurgin » Sat Mar 29, 2014 6:40 pm
hmm ok. I'm not sure what I'm experiencing. I've talked to a few Chevy mechanics and they have said these engines do experience some engine slap which sounds like a bottom end issue but they said you can have that noise and you'll get another 100k out of it. just curious what anyone else has experienced. thanks
jhurgin
by djthumper » Sat Mar 29, 2014 10:40 pm
no problems like that with mine.
by DirtyBacon04 » Sat Mar 29, 2014 11:19 pm
Same here. No noises like that. I get a somewhat heavy vibration at idle, but i know its motor mounts. Just too lazy to change them.
by Edubarajas » Sun Mar 30, 2014 12:38 am
Same here sometimes I forget it's even on that's how quite it is!
Edubarajas
by jhurgin » Sun Mar 30, 2014 10:41 am
once it's up to temp it's as quiet as can be. Like one of you said, I sometimes think its shut off at a stop light. just thought i would ask. thanks
jhurgin
by blazinlow89 » Sun Mar 30, 2014 12:49 pm
DirtyBacon04 wrote:Same here. No noises like that. I get a somewhat heavy vibration at idle, but i know its motor mounts. Just too lazy to change them.
Mine needs them replaced, however I have been suffering from similar symptoms lately. Lazy, broke and its been too cold.
As for engine noise, the only thing I hear on startup is the roar of the fan. After about 20-30 seconds it goes away and I have some lifter noise. It is more prevalent in the winter, and typically quiets down after a few minutes. Some mornings it can also sound like a powerstroke, it depends on the temps and I attribute that to a leak at the exhaust manifold.
I will say I hear more lifter noise now using Mobil 1 than I did when using Royal Purple. I typically follow the OLM for oil changes, and that has been anywhere from 10k-14k miles. I switched to Mobil 1 as it was cheaper and I figured hell it is highly recommended. I will not be using it again.
blazinlow89
by KingBird » Mon Mar 31, 2014 10:57 pm
KingBird
