offroadTB.com • View topic - MrSmithsTB's Build - 2002 Chevrolet Trailblazer
by MrSmithsTB » Sat Sep 12, 2009 5:33 pm
2002 Chevy Trailblazer "Z71"
4x4 GT4 G80
Suspension Modifications:
Front:
Liftmeister 2.5" suspension lift
Bilstein HD struts
Rear:
Liftmeister spacers
Z71 shocks
SMAXX front sway bar end links, rear sway bar removed.
Exterior Modifications:
2" body lift
MarkMC 1.5" spacers 6x5-6x5.5
Stock Silverado 17x7.5 Steelies painted satin black
BFG Mud Terrain LT255/75/17 Load Range D
blacked out grill/mirrors/door handles/roof rack
Whistler modded headlights w/35w 6k HIDs
Custom CB antenna mount under D-pillar
Engine Modifications:
Color matched engine plastics
Dynomax muffler and res. delete with side exit and stainless tip
ChromeIntakes CAI
Interior Modifications:
Black & Tan 2 toned interior
Color matched gauge bezel, vent bezels, switch panels, and handle trim.
LT cloth seat covers
Leather wrapped steering wheel
Recovery Equipment:
2 30'x3" recovery straps
tow rope
shackles
first aid kit
portable air compressor
Electrical Modifications:
Remote start/keyless entry
Pioneer CD player with aux input and preouts
Custom sealed box for 2 10" poineer subs.
Custom color matched 1200w amplifier
Current photo:
by MrSmithsTB » Mon Sep 14, 2009 2:21 pm
Here is the cutting I had to do:
Front of lining
Rear of lining
Cut rocker panel and bent tab 180deg for new mounting point.
I also replaced/upgraded my CV clamps since the inner boots decided to spring leaks on me.
These were uber easy to install, stronger the the originals, and can be adjusted as the start to "relax". Not a bad fix until I can afford to start replacing shafts.
by MrSmithsTB » Sun Sep 20, 2009 7:52 pm
Installed SMAXX sway bar end links.
Also, put in a CB today. Still need the antenna and PA.
Also, I am officially a Trail-Blazer.
by MrSmithsTB » Sat Oct 10, 2009 10:35 pm
Edit.
by MrSmithsTB » Thu Oct 15, 2009 6:04 pm
Postman dropped me a package today. The base was tan when it arrived. Thanks to Krylon Fusion, it is now hunter green. Not an exact match, but closer to my color and it will stand up to the weather. Now, off to install it in the rain..
by MrSmithsTB » Sat Oct 24, 2009 2:13 pm
Install of CB, antenna, and newish leather wrapped steering wheel completed.
by MrSmithsTB » Tue Nov 24, 2009 2:13 pm
New tires.
by MrSmithsTB » Fri May 14, 2010 8:17 pm
Riding high again. Marks lift with 265/75/16 BFG All Terrains.
by MrSmithsTB » Mon Sep 20, 2010 6:24 pm
Jan '11
Brief hiatus from modding, in which vehicle was returned to stock for a buyer that backed out on the deal
by MrSmithsTB » Sat Sep 03, 2011 5:05 pm
August '11:
Addition of 2" body lift and removal of rear sway bar.
