Update at 116,000 miles: rt rear hatch trim and drivers door experienced some minor trail damage.
![Image](http://i1162.photobucket.com/albums/q526/trailburner68/bf29ee2b.jpg)
2005 Chevrolet Trailblazer LS
U 805K Dark Gray Metalic
Drivetrain:
-stock
-LL8 4.2 I-6
-automatic trans
-selectable 4x4
-GU6 3.42 non locking differentials
Suspension modifications:
-3" Liftmeister lift. Bilstein struts up front. Rancho 5000 rear shocks.
-replaced upper and lower balljoints
-replaced stabilizer links front and rear
-"Mall ready" ....although rated for it, I never go to the mall.
Exterior modifications:
-removed plastic door guards (falling off)
Engine:
-cold air intake with k&n filter
-current codes needing addressed:po410, po495, po526
-replaced entire fuel pump sending unit assembly
Exhaust modifications:
-3" center in/out flowmaster delta 40 series
-Custom 3" exhaust resized to fit 2 3/4" stock blazer pipe with stock exhaust exit location
-5" stainless tip
Interior modifications:
-Bible in the glove box
-heavy duty rubber floor mats
Recovery/Emergancy equipment: I keep a few essentials in the blazer but I have two large wheeled camping gear bags with survival/camping/bug out/emergency equipment packed in them. I use the bags to make switching back and forth from the blazer to my Z71 Silverado a lot easier.
-2 20' 3000 pound (working load, 9000 pound breaking point each) tow straps
-standard front tow hooks
-"harbor freight" survival knife
-3 pound sledge hammer
-machete
-folding saw
-20' coiled air hose with valve stem connection and air chuck
-hand crank weather radio
-4 U.S. Military M.R.E.'s
-glow sticks
-black electrical tape
-military duct tape
-bellsouth 22 channel frs 2 way radio w/2 to 5 mile range depending on terrain (it's a walkie talkie)
-bushnell 12x25 compact binulars
-3-D battery powered 500 lumen focusing flashlight
-20' jumper cables
-firearm lock box
Tires/wheels:
-LT245-75-16 Mastercraft courser axt
-stock aluminum 16x7 wheels (plastidip soon???)
Electrical modifications:
-jvc stereo
-1000 amp duralast gold battery (battery box & rusted bracket DELETE!)
-dealer installed rust inhibiters (junk)
ABS disabled (turned psycho so I pulled the fuse)
