Chango wrote: Should I double dip and add additive in with the oil even though it says it has it already??
DustinC1989 wrote:Could run Dexron LS 75-90, that certainly doesn't need any additive
The Roadie wrote:The SS limited slip is different than our G80 locker. I use Mobil 1 that has the LS additive in it already, and it can't cause harm. But paying money to add more when the utility isn't there for the G80? No purpose.
So many members doing so many projects....declining number of brain cells to process them.....Chango wrote:I guess I should have put that I am talking about the SS rear.
The Roadie wrote:So many members doing so many projects....declining number of brain cells to process them.....Chango wrote:I guess I should have put that I am talking about the SS rear.![]()
If you're putting in the SS axle, you should also be changing out the LS to a locker while you're in there. At least I would be.
