Happened yesterday leaving our campsite from night 1 at TECORE. Going up a rock ledge, my front diff was not engaged (suspect disconnect/actuator, good thing I just bought a spare). Trying to make it up the rocks, the back spun a little too much and then all of a sudden... BANG, CRACK, POP! This came at the exact same time as a low oil pressure warning from being on the incline. Killed the engine and strapped my truck up the guy in front of me... lowered me back down to level ground. We couldn't see anything broken, so I let the oil level return, started the truck and tried to inch forward, more grinding and then another pop. That one finally punctured the diff cover.
Rory took a bunch of pics and I'm pretty sure James got video of it. Will have to wait until they get back later today to make sure. I took this pic after getting to clearing and making sure I could limp home.
I kept the truck in neutral and winched up part of the hill and then was pulled up the rest and out to a flat clearing. Took out the driveshaft and got the front up in the air to play with the disconnect. We got the front diff engaged and the fronts going. I was able to limp off the mountain in front wheel drive. I got to Advanced Auto, cleaned up the crack, and put some jb weld on to help hold oil. Couldn't get the fill plug off, so I filled diff from the breather tube. Limped home from VA stopping periodically to make sure diff had oil.
So now I'm looking for an 8.6" axle and I'm thinking its time to regear! Found a 2002 Envoy XL axle with 4.10s only about 1 hr from me from an LKQ location. It is listed with 115k miles... no indication of a locker, but it is only listed at $300, so I don't think it has the G80. Detroit and ARB lockers are a little too pricey for me at this time, as I will also have to find a front diff with 4.10s to match.
Any suggestions or words of wisdom for me while on my search?
Brake hardware is the same. I'm using EXT e-brake cables to avoid triggering the e-brakes when getting all flexy. I kept the other hardware off my old axle as spares. It all interchanges. Even the control arms.
