offroadTB.com • View topic - CV boot that stays together?
by v7guy » Thu Dec 06, 2012 2:51 am
well the other day it was noticed that the silicone boot has torn. Maybe on my last outing in Jersey, maybe not. Don't reckon I'll ever know. It's a small 1/2" tear inbetween the ribs. Maybe I'll look for a detroit axle rebuild, maybe I'll toss on another silicone one. I dunno yet. This is the longest lasting boot yet. But it's still annoying.
by HARDTRAILZ » Thu Dec 06, 2012 7:52 am
My Detroits have lasted better than any other.
by v7guy » Fri Dec 07, 2012 2:25 am
the biggest issue seems to be the number of pleats. Everything else I was finding a year ago had three and it's not enough... hell that's what the detroits are showing on ebay. I don't think I'm any higher than Kyle though. Maybe it's just the fact they are using neoprene for the boots that keeps them alive in the three pleat style. I'll have to find some neoprene boots and give it a shot. I'd hate to replace the whole axle considering they're only a year old.
by fishsticks » Fri Dec 07, 2012 2:33 am
I never had a boot problem with Masterpro's (Oreilly House brand). I broke outer CVs on those, but no more often than I did with the OEM ones.
Best part was plopping it down on the counter and walking out with a new one for free when they did break.
The old Trailblazer -
by HARDTRAILZ » Fri Dec 07, 2012 2:35 am
by v7guy » Fri Dec 07, 2012 4:06 am
I miss oreilleys lol
Every AutoZone and advanced auto half shaft I've had has destroyed the boots within hours of putting them on. I'm only 41"at the top of the fender opening. I dunno why I have no luck.
by v7guy » Mon Apr 15, 2013 11:40 pm
Rockauto has the neoprene boots for $12.60. I'm gonna give it a try. The Detroit axle rebuilds use neoprene and seem to hold up, so maybe this will be the ticket despite being three pleats.
MOOG/PRECISION Part # 5444 More Info CV Boot
Neoprene Material; Front Inner; 4WD
http://www.rockauto.com/catalog/moreinf ... cc=1424281
http://www.rockauto.com/catalog/x,carco ... ttype,2284
Maybe this should be in the diff/axle section?
by dvanbramer88 » Tue Apr 16, 2013 7:02 am
The saga continues... Good luck man.
by v7guy » Thu Apr 18, 2013 7:59 pm
My impressions of this boot are that it's probably the best option I've tried yet. The install was basically the same as for the silicone boot except I didn't have to cut up the old boot to adapt anything. This boot appears to be made for the 360 platform and installs with no fuss. The neoprene is significantly thicker than the silicone and drastically more compliant than the stock boot. I installed this on one of my old stock spares that had a ripped boot. It didn't seem to have any appreciable wear so I should be good to go assuming the boot holds up. I used some stainless worm gear clamps since that seems to work well and then I wrapped it in electrical tape and coated the tape with some liquid electrical tape to hopefully keep it from unraveling.
I'll install tomorrow and update when it fails.
Here's some quick pics of the process. Some of them are blurry, apologies.
by soldier32mp » Fri Apr 19, 2013 1:33 am
The cartons selects are built better and have a extended boot. I switched my old ones out and put these in and even with marks 3' lift and the 81114 no rip or failure yet
soldier32mp
by v7guy » Fri Apr 19, 2013 8:27 am
by HARDTRAILZ » Fri Apr 19, 2013 8:34 am
I did not have hood luck w cardones as mentioned. Some people like em though.
by v7guy » Tue Apr 23, 2013 10:44 pm
It may be of interest that as of yesterday the other silicone boot has completely torn apart. The neoprene is still holding up fine.
by v7guy » Mon May 06, 2013 12:18 am
haven't been off-road once, drivers side neoprene boot tore open at the top of a rib. Nothing else to update.
by Norcrosski » Wed Apr 16, 2014 3:01 am
I know this thread has been dead a year but what have you done to keep a boot together?
Norcrosski
by v7guy » Wed Apr 16, 2014 6:29 am
I took em out for some maintenance the other day, one silicone boot was still intact and the neoprene one was doing fine as well. Probably a half dozen trips offroad.
The neoprene is a good bit thicker and the silicone one is fairly delicate. I'd likely go with neoprene replacements held on with the worm gear clamps or the detroit axle rebuilds that Kyle commonly recommends (assuming they're still using the neoperene boots).
by Norcrosski » Wed Apr 16, 2014 11:02 am
I am running the Detroit axles(with the neoprene boots) they have been in for about 4 months and I tore both inners in same week and only one time offroad just to see how my new wheel and tire set up did. So you recommend the moog boot 5444 that you have know to somebody with the same trouble
Norcrosski
by v7guy » Wed Apr 16, 2014 4:26 pm
It's what I'm currently using and it seems fine. Oddly enough the other silicone one has held up ok as well, but the neoprene seems a lot more durable.
When you swap boots take care to make sure the boot isn't overly high or low on the shaft.
by ErikSS » Wed Apr 16, 2014 7:41 pm
:friday:
by v7guy » Wed Apr 16, 2014 8:34 pm
Just some routine maintenance man, I'll pop CVs back in there shortly
