Dana 44 Swap
by fishsticks » Mon Apr 16, 2012 12:34 pm
Nakashige wrote:ok going leaf then would be the cheapest correct found my rear axle at least from a 91
Yes. I believe 91s came with 63" rear springs. Steve did you use 63s in your rear or 52s?
Either way you can swap around.
by chevycrew » Mon Apr 16, 2012 4:26 pm
I used 52" rear springs, front and rear. I used the lower control arm pocket turned into a leaf mount. Moved the axle about 4" back.
by Nakashige » Mon Apr 16, 2012 9:38 pm
Well I ended up having to deal with a situation today going to talk about the truck tomorrow
Nakashige
Vendor
by Nakashige » Wed Apr 18, 2012 1:02 pm
Ok so Early 70s Dana 44 LP will it work?
Nakashige
Vendor
by chevycrew » Wed Apr 18, 2012 8:03 pm
It will work the same as a high pinion. I just don't see why.
by Nakashige » Wed Apr 18, 2012 9:01 pm
What part don't you see why. the LP?
Nakashige
Vendor
by chevycrew » Wed Apr 18, 2012 9:36 pm
Yeah, with the cost of a hp 44 being so cheap, I dont see what could be gained by running a low pinion. The amount of lift needed to clear the pan will put you into driveline problems in the front with only running a single case. (shorter shaft than mine)
If you must run a low pinion axle (its also weaker) then I would have it cut and turned to raise the pinion.
by Nakashige » Wed Apr 18, 2012 11:25 pm
I am having a issue finding a hp 44 might of found one I will find out in the morning
Nakashige
Vendor
by fishsticks » Thu Apr 19, 2012 1:46 am
Nakashige wrote:I am having a issue finding a hp 44 might of found one I will find out in the morning
IMO best to wait for the right part than push forward with junk.
People will just about GIVE you an HP 44 out here. Everyone wants a 60 these days.
by Nakashige » Thu Apr 19, 2012 1:53 am
I have had no issues finding 60s the 44s are more illusive
Nakashige
Vendor
by chevycrew » Thu Apr 19, 2012 2:43 am
Maybe its a sign!
by fishsticks » Thu Apr 19, 2012 3:15 am
chevycrew wrote:Maybe its a sign!
+1
by Nakashige » Thu Apr 19, 2012 11:21 am
Its a sign telling me to buy the D60 for 200 and convert it to single wheel drive
Nakashige
Vendor
by fishsticks » Thu Apr 19, 2012 1:24 pm
A D60 for $200? What's wrong with it?
by Nakashige » Thu Apr 19, 2012 2:52 pm
I need to pass inspections whats the wheel mounting surface to wheel mounting surface on a D60 isn't it close to 70in?
Nakashige
Vendor
by chevycrew » Thu Apr 19, 2012 3:16 pm
Yeah, 69.5" wide on a 60.
by Nakashige » Thu Apr 19, 2012 3:50 pm
Yeah the D44 is 65inches
Nakashige
Vendor
by Trail X » Thu Apr 19, 2012 3:53 pm
Curious - what does that have to do with inspections? Do they actually measure hub distance?
by Nakashige » Thu Apr 19, 2012 4:28 pm
MA is Very strict with everything. I am pushing it with the SAS a TB has a Max Lift of 8in over stock including tire size. Also very strict with How much tire sticks out beyond fenders. I have had a town cop pull me over for factory tint. A D44 will be about the same as stock WMS to WMS wise so I can figure out a smaller fender flare like what Roadie did for tire coverage. Unlike Steves or Antons that stick out farther.
Nakashige
Vendor
by dvanbramer88 » Thu Apr 19, 2012 5:50 pm
Nakashige wrote:MA is Very strict with everything. I am pushing it with the SAS a TB has a Max Lift of 8in over stock including tire size. Also very strict with How much tire sticks out beyond fenders. I have had a town cop pull me over for factory tint. A D44 will be about the same as stock WMS to WMS wise so I can figure out a smaller fender flare like what Roadie did for tire coverage. Unlike Steves or Antons that stick out farther.
I'd say you're living in the wrong state my man.
