offroadTB.com • View topic - 4Crawlin Build Thread
by HARDTRAILZ » Tue Jul 12, 2011 9:00 am
Well done. I am now thinking leaf springs will be the way to go. Better setup than our stock and simple. Now that I have a daily driver I can hopefully get mine under the knife. It turned out great, again well done.
by chevycrew » Tue Jul 12, 2011 10:55 am
Not done, I still have a bunch to do.
but thats a negative on roof rack, light bar, or stickers... (Unless they are Ultimate Adventure stickers)
I have been modding the crap out of my car and this got back burnered a little bit.
Current to-do list.
Black box for manual control of trans
Upgraded cables for trans shifters
Reinstall front locker (warranty)
Wheel more...
then-
hydro assist
bumpers
skidplates
etc...
by dvanbramer88 » Tue Jul 12, 2011 11:44 pm
Your INSANE! i love it haha, i saw your finished pictures and sat in awe... Your one crazy SOB, :cheers: Nice truck, all the effort paid off.
by chevycrew » Tue Aug 09, 2011 6:15 am
Minor update.
Front locker back in and working good.
Trans shifting issues in 4 low resolved. I still only have 1st and 2nd in low-low, but I can live with that.
Service 4wd light went out when TCCM was removed.
Now:
Bypass brake and abs warning lights. (tired of troubleshooting and looking at them.)
Replace my t-case shift cables.
Slide fuel tank back a couple inches. (cut frame mounts off and move back)
Add a couple leafs to the rear.
Seal off where I cut the lower rear quarter boxes off.
Bumpers and exo
Hook up e-brake cables
Im hoping to put about a thousand miles on it for hunting this year, most likely on my 37's though.
by Trail X » Tue Aug 09, 2011 9:05 am
De-soldering the warning lights may be the easiest way.
by chevycrew » Tue Aug 09, 2011 5:09 pm
by DirtyBacon04 » Sat Aug 13, 2011 1:42 am
by chevycrew » Sat Aug 13, 2011 2:19 am
its a pavement pic. Not worthy of the homepage.
by chevycrew » Sun Aug 14, 2011 8:29 pm
Little more done yesterday and today.
To stop my fuel tank from rubbing on the second case, I decided not to move it back. It was more work than I wanted to mess with.
So I dropped the tank, drained it, (Fold a coat hanger over and shove it in the filler neck to release the check valve) removed fuel pump, filled with water, drained water, the got out the torch!
Just a small plumbing type torch (heat gun would be better!) These tanks are double layer: black outside, white inside. the outer layer melts rather easy, but it takes more heat to soften the white, so go slow! I ended up pushing the front edge back about an inch where I needed clearance.
Fill with water to test for leaks, drain, dry, re-install and good to go.
Bad thing, to pull t-cases, tank must come out. But thats only a 15 minute job.
by Trail X » Sun Aug 14, 2011 9:22 pm
You're lucky with the 2002, there is only two quick connectors. Those things took the majority of my time when I dropped the tank.
by chevycrew » Thu Sep 01, 2011 6:37 pm
So I broke one of the first t-case shifter cables, so ordered some new from Midwest Control Products.
These are a little bigger!
by navigator » Thu Sep 01, 2011 9:44 pm
that is pure beef right there!
by chevycrew » Mon Sep 05, 2011 5:05 pm
New shift cables and fire ext. installed.
by HARDTRAILZ » Mon Sep 05, 2011 10:08 pm
Nice. I think I may steal that placement for extinguisher
by chevycrew » Tue Sep 06, 2011 12:30 am
Go for it! One of my requirements was to have the extinguisher within reach of driver and passenger, this was the only place I saw to do this.
by BSalty » Tue Sep 06, 2011 1:04 pm
I just had to say that the pictures on here don't do it justice. After seeing it in person this thing is unreal. It goes without saying he knows his stuff, but I was really impressed with how cleanly everything was done. Most rigs I see of this caliber are just pieced together, he did a good job with placement on his rig.
Formerly known as CBRguy.
BSalty
by navigator » Tue Sep 06, 2011 2:09 pm
the cool part about it is it happened so fast too. It is amazing how much thought and detail went into it and yet it was done so quickly.
Shoot, it took me longer to pull the trigger on a used rough country lift and get it installed!
by chevycrew » Sun Sep 11, 2011 7:17 am
So I went and measured a stock TB tonight.
I measured 13 1/2 to the center of the wheel, and 8" to the lowest point of the oil pan drain plug.
Mine measured 23 1/2 to the oil pan plug, and 18" to the axle centerline.
In other words, I have 11 inches of lift over stock, plus a 1" body lift.
by chevycrew » Thu Sep 22, 2011 4:09 am
Some pics!
Double wall sliders...
Exhaust...
Mudflaps...
by chevycrew » Thu Sep 22, 2011 4:11 am
More...
His and Hers...
Side view on 37s...
