yeah, both of the shafts, the cardone and the duralast are less than a month old.
replaced the torn boot with the silicone boot
pulled off the old clamp
took off the snap ring
removed the bearings
axle with no bearings
removed the boot
pulled the silicone boot down until it slipped into the groove on the axle
clamped it
put the bearing and snap ring back on the axle
the directions in the silicone boot box said you needed to retain the rubber piece on the tripot. This piece doesn't exist on the aftermarket axles and you cant use the stock piece because the aftermarket tripots are a different shape than stock
so i cut the after market boot to retain the rubber piece that goes around the tripot, cleaned both up and put a dab of silicone to help hold it in place on the tripot.
I became a little worried about the sharp edges of the clamp so I wrapped some electrical tape around it.
new boot stretched... plenty of flex
