Running wires through the firewall?
by KE7WOX » Wed Nov 03, 2010 11:13 pm
Does anyone know of the locations of grommets or where holes can be drilled to run wires through the firewall? I plan on running at least one antenna cable, the PA speaker wire and wires for extra driving lights
by HARDTRAILZ » Thu Nov 04, 2010 8:38 am
There is one on the drivers side I used for a couple wires. I think I slid one through and poked an extra hole in the grommet for the other.
by Philberto » Fri Nov 05, 2010 7:43 am
I ran mine through the big boot that carries all the other wires into the engine bay. Either that or the steering column boot. Will check when I rewire.
by janesy86 » Fri Nov 05, 2010 8:58 am
Philberto wrote: the steering column boot.
Yep thats what I did for my Hellas and strobes that I have up front. Just poked a small hole in it and taped it up.
Return to Electrical / Radios
