3" BODY LIFTS FOR SALE!
Products offered by our vendor: high-voltage
by markmc » Sat Sep 29, 2012 2:23 am
navigator wrote:is the body lift for the EXT the same as the SWB?
Yes, The kit will fit both SWB and EXT.
Only dif is in the V8 to I6 radiator drop brackets.
The V8 has a slightly taller radiator that requires a little modding of the drop brackets.
A hack saw, couple 1/4x20 x1" bolts & nuts, drill and 1/4" bit will take care of the dif..
markmc
Rank: Mall Rated
by navigator » Sat Sep 29, 2012 7:31 am
good info, thanks Mark.
by 06MidnightBlue » Sat Sep 29, 2012 9:57 am
CrimsonxRebel wrote:i have the rough country leveling kit and all it is is a 2.5 inch spacer in the front and a 1.5 inch spacer in the back would i have to take that off to get this kit put on?
It's actually a 2 inch front spacer and a .75 inch rear spacer.
06MidnightBlue
by CrimsonxRebel » Sat Sep 29, 2012 1:06 pm
Yeah I couldn't remember what they had but I ended up just putting the front on and not the back cuz it was level after the front
CrimsonxRebel
Vehicle: GMC Envoy XL
by The Roadie » Sat Sep 29, 2012 1:16 pm
Raising the rear is functionally useful (to me at least) because then if you get a rock jammed under your frame rail it gets LOOSER as you travel forward.
Offroading for most of us is about functionality, not appearance.
by Mgebhard » Sun Dec 20, 2020 3:10 am
Long outdated post I see, is there anywhere still making a 3" body?? Recently bought an 03, it has the 3/2.5 level kit sitting on 265/75/16s. ID like to go to a 33 without trimming a ton so my best guess would be a body lift? If theres other ways im all ears!! Thanks in advance
Mgebhard
by HARDTRAILZ » Sun Dec 20, 2020 8:25 am
Two inch Zone is only complete kit.
Couple were selling a 3 inch version that was basically them just ordering blockd n bolts n extension then selling to you. Bunch of bumper trimming but not actual relocation brackets. You could easily create your own if you go that route.
by QPat19 » Tue Jan 12, 2021 12:18 am
Love to buy one!!
QPat19
Return to High Voltage Stuff
