Random Rig Shots
by BWGuy » Wed May 15, 2013 10:16 am
Super easy front door removal... 3 screws, one electrical connector, lift off and done. Makes it much easier to lean out and see where you're stepping. Sheds a few pounds too.
TB No Doors.jpg (158.46 KiB) Viewed 23523 times
BWGuy
by jonbo2002 » Wed May 15, 2013 10:22 am
BWGuy wrote:
thinkin you're hanging around to many Wranglers lol
jonbo2002
by HARDTRAILZ » Wed May 15, 2013 11:05 am
I want half doors!
by fishsticks » Wed May 15, 2013 11:54 am
I've been DDing my crawler for the past few weeks and the doors have been off most of that time. Depending on your state, you'll need to install some auxiliary mirrors if you're driving on the street.
I like it so much I'm going to make some tube doors this summer.
by mikekey » Wed May 15, 2013 11:55 am
WOW, on an EXT none the less. I've seen guys in S10 4 door blazers rolling around with all 4 doors off. Looks retarded. But, that's my opinion. To each his own.
by jonbo2002 » Wed May 15, 2013 12:00 pm
HARDTRAILZ wrote:I want half doors!
sawzall! :poke:
jonbo2002
by Cable810 » Thu May 16, 2013 4:14 pm
Had to mow today!!
by Moots1288 » Thu May 16, 2013 4:33 pm
by mikekey » Thu May 16, 2013 5:29 pm
One certified off-roader and a mall crawler parked behind it. :poke: :finger:
by dvanbramer88 » Thu May 16, 2013 10:02 pm
Pretty much.
Moots is a prime example of "I blew all my money on modifying my truck so now i can't afford gas to go wheeling."
Jason is taking much longer with his truck, but at least he actually shows up to offroad trips.
by Moots1288 » Thu May 16, 2013 10:06 pm
dvanbramer88 wrote:Pretty much.
Yup that is true huh.. Sounds about right..
by SaltWaterDrinker » Fri May 17, 2013 7:51 am
Moots - just come down to the Pine Barrens in August and drive her through some thorn trees. After that, no one will be able to tell the difference...mall crawl or not.
SaltWaterDrinker
by SaltWaterDrinker » Fri May 17, 2013 8:32 am
I'm getting there!
SaltWaterDrinker
by Moots1288 » Fri May 17, 2013 8:41 am
SaltWaterDrinker wrote:Moots - just come down to the Pine Barrens in August and drive her through some thorn trees. After that, no one will be able to tell the difference...mall crawl or not.
Just come rausch..
by SaltWaterDrinker » Fri May 17, 2013 8:48 am
I plan on it!! Hopefully well see you there too?! ;p
SaltWaterDrinker
by HARDTRAILZ » Mon May 20, 2013 1:37 pm
Some Shots from the Weekend...
by Conner299 » Mon May 20, 2013 7:01 pm
HOLY CRAP! Did you un-plasti-dip your hood? Any long term effects, if so? Looks good without the moldings, too.
EDIT: NM... The angle of that second to last pic just makes it look like you did. I can see it, barely visible, above the brush guard. :facepalm:
Conner299
by HARDTRAILZ » Mon May 20, 2013 7:55 pm
Plasti dip is there but red stripe is gone.
by DirtyBacon04 » Tue May 21, 2013 3:20 am
Just found this one from rain'o'rama
by The Roadie » Tue May 21, 2013 11:24 am
hehe.
