offroadTB.com • View topic - Rear Control Arms!
Rear Control Arms!
Products offered by our vendor: gotricebih
Moderator: gotricebih
by gotricebih » Tue Aug 10, 2010 2:10 pm
Once Kyle gets the arms installed he is gonna get a few pics for all of us!
He is gonna get some of the tire centered in the wheel well, and also some shots of his truck flexing. :thumleft:
gotricebih
by gotricebih » Tue Aug 10, 2010 2:12 pm
gotricebih
by fishsticks » Tue Aug 10, 2010 2:14 pm
I'm interested to see how this affects our rear brake lines... I don't recall there being a huge amount of play. Hard flexing may stretch things a bit...
The old Trailblazer -
by gotricebih » Tue Aug 10, 2010 2:18 pm
gotricebih
by MrSmithsTB » Tue Aug 10, 2010 2:20 pm
by glfredrick » Tue Aug 10, 2010 2:40 pm
Typically, there is some room in the steel lines above where they are fastened to the frame. Many lift kits just stick a piece of metal for an extension in the kit to deal with brake line length.
Sometimes with more travel, one has to scope out the parts book and find longer lines. The Parker store is also an alternative -- they can custom build brake lines in multiple styles and colors with just about every end under the sun.
== The United Christian Off-Road Alliance, a family friendly place
glfredrick
Contributing Author
by gotricebih » Wed Aug 11, 2010 11:38 am
Kyle is going to try to install them tonight, if not tonight he said definately tomorrow. After they are on hopefully he will be able to answer everyones questions!
gotricebih
by The Roadie » Wed Aug 11, 2010 12:14 pm
by glfredrick » Wed Aug 11, 2010 2:17 pm
I've not tried, but I'll bet that something will work... :lol:
I've used lines from a lot of other stuff on off-road vehicles by bending or moving a tab, etc.
glfredrick
Contributing Author
by OregTrailBlazin » Wed Aug 11, 2010 2:28 pm
Johnny Kurz
General Manager
541-474-2879
OregTrailBlazin
by HARDTRAILZ » Thu Aug 12, 2010 2:57 pm
I got them painted up and took some pre-install maesurements. The bent pass lower has pulled the axle an extra bit forward on that side, so I need to get these on. The plan is to install tonight, but here are some pics with measurements.
Stock pics...
drivers side
Drivers front of wheelwell--right at 3 inches
down lower at 2 inches
Drivers rear of wheelwell--4.5 ish
little lower--just under 4
[SIZE="4"]Passenger side[/SIZE]
FRONT
2.5 inches
1.5 lower
Behind tire high--4.75ish
lower--4ish
The brake lines will probably benefit from being detached from frame, but I think roadie has a point that a cut and splice away from end may be simpler in our situation.
by Trail X » Thu Aug 12, 2010 3:10 pm
When fully stuffed - how close are your tires to the rear sheet metal?
by HARDTRAILZ » Thu Aug 12, 2010 3:41 pm
by Trail X » Thu Aug 12, 2010 4:04 pm
Right, my worry is that as the tire goes up, it goes further back - if you move the axle back 1", are you going to be running the tire into the rear sheet metal on full stuffage?
by janesy86 » Thu Aug 12, 2010 4:10 pm
So then cut, as long as its not hitting the door... then if wanted cover up with some flares..
by Trail X » Thu Aug 12, 2010 4:30 pm
I don't think it's as simple as the fronts. I could be wrong.
by gotricebih » Thu Aug 12, 2010 8:01 pm
gotricebih
by MrSmithsTB » Thu Aug 12, 2010 8:06 pm
by HARDTRAILZ » Fri Aug 13, 2010 9:50 am
Passenger Side- bent side
front low 2.5 vs 1.5 previous
Front high 3.5 vs 2.5
Rear low 3.5ish vs 4
Rear high 4.25 vs 4.75ish
by HARDTRAILZ » Fri Aug 13, 2010 9:52 am
Drivers Side
Front high... 3.5 vs 3
Frnt low.. 2.5ish vs 2
Rear high... 4 vs 4.5
Rear low... 3.75 vs 4
Install Pics
Return to GR Fabrication
