offroadTB.com • View topic - Rear Control Arms!
Rear Control Arms!
Products offered by our vendor: gotricebih
Moderator: gotricebih
by gotricebih » Tue Aug 24, 2010 1:46 pm
Johnny joints, summit machine joints, ballistic joints.. I've looked at pretty much everything. I emailed a few companies to see if they can make something work.
gotricebih
by teebes » Tue Aug 24, 2010 2:07 pm
teebes
by gotricebih » Tue Aug 24, 2010 2:56 pm
Specs on what? Heim joints?
gotricebih
by teebes » Tue Aug 24, 2010 6:48 pm
teebes
by gotricebih » Tue Aug 24, 2010 6:56 pm
Aren't heim joints all adjustable?
gotricebih
by teebes » Tue Aug 24, 2010 7:00 pm
As in with a shank on them for some length adjustability? Believe most are. Just curious regarding the width, spacers, etc.
teebes
by gotricebih » Tue Aug 24, 2010 7:19 pm
I haven't looked into heim joints really. Then I would have to use tube adapters which would add to cost.
gotricebih
by Zero » Tue Aug 24, 2010 7:31 pm
Hahaha one step forward, 2 back with this project it seems. Im sure you guys will solve it though. Im sure the second gen. rear CA's will be awesome and worth every penny.
by gotricebih » Tue Aug 24, 2010 7:56 pm
I found some Summit Machine joints that have the correct bolt size....... but still the wrong mounting width. Closest one I've found so far tho!
gotricebih
by Trail X » Tue Aug 24, 2010 8:18 pm
Yeah, the 14mm 2" width isn't a common combination it seems, I've been googling myself. :work:
What is the down side of using spacers or washers on either side of the joint?... BDS currently ships their rear shocks that way... our guys seem to accept it as the norm since we've got a lot of iniquities. I guess it would complicate the installation a bit though.
by gotricebih » Tue Aug 24, 2010 8:36 pm
gotricebih
by gotricebih » Thu Aug 26, 2010 8:00 pm
Finally found some flex joints that will work!
Pricing will be:
$250 for .5" or 1" extended with poly bushings.
$350 for .5" or 1" extended with poly/flex joint.
gotricebih
by SteveTB03 » Thu Aug 26, 2010 11:07 pm
I'm confused on what a flex joint is and what the benefits are of it?
Go Big & Go Broke
SteveTB03
by Trail X » Thu Aug 26, 2010 11:18 pm
Poly bushing is essentially a bushing that compresses when you flex the rear axle. The "flex joints" have a ball joint on one side that allows the arm to rotate free of the frame or axle. If you articulate a lot, the poly bushings will wear and need to be replaced eventually. The flex joints will have longer life and they restrict your articulation less, allowing the axle more freedom.
Correct me if I'm wrong.
by Zero » Fri Aug 27, 2010 1:24 am
What is the best way to decide if you require the .5" or 1" length. Would the average lift and 32" tires or less only require the .5"?? :work:
by HARDTRAILZ » Fri Aug 27, 2010 1:35 am
I dont know that .5 inch would really gain you anything. It wont center the axle. You would get strength, but I dont know why you would not go an inch.
by gotricebih » Fri Aug 27, 2010 9:17 am
gotricebih
by gotricebih » Fri Aug 27, 2010 9:19 am
gotricebih
by teebes » Fri Aug 27, 2010 3:25 pm
Kyle.. By your estimates, will 1" be long enough for the next size up in tires? What's your rear suspension situation looking like now?
teebes
by HARDTRAILZ » Sat Aug 28, 2010 1:04 am
Return to GR Fabrication
