offroadTB.com • View topic - Stabilitrac Activation after larger tires?
by PROSPHOTO » Thu Jun 02, 2016 9:37 am
After my lift plus 32"tires, I'm feeling the Stabilitrac kicking in around turns over 10mph or so. I'm guessing this is a normal occurrence, but if annoying has additional information/experience I would spirochaete heating about it. I'm not getting any warning lights or a message that is kicking in, just feeling the activation through the abs. Normal?
-Mike
PROSPHOTO
by bartonmd » Thu Jun 02, 2016 10:16 am
Yeah, I get more of the activation with the larger tires. What tires are you running? I had Duratracs for a minute, and it would seriously activate with those all the time, because of the tall/soft tread causing the rear to slide/drift around a bit and the yaw and steering sensors to not agree. I can still do it while hard braking in a turn with the BFG KO2's, but it's not nearly as bad as with the Duratracs.
by PROSPHOTO » Thu Jun 02, 2016 4:06 pm
I have the Duratrac 255/75R17's... Just going to get into the habit of deactivating on dry pavement
-Mike
PROSPHOTO
by Rickalicka18 » Thu Jun 02, 2016 4:17 pm
Happens all the time to me. Never had a problem with the traction control coming on in the front before the lift and tires. I just think its because I'm driving too fast though... But I have Yokahoma Geolander 265/70/17s.
Rickalicka18
by Moots1288 » Sun Jun 05, 2016 12:44 am
Happens to me too, but I also have the front locker
by navigator » Wed Jun 08, 2016 4:37 pm
Mine engages off-road but never really on-road. Mine has pretty much been the same with 30.5, 32s, and 33s with the even with the front locker.
by HARDTRAILZ » Thu Jun 09, 2016 1:41 pm
I dont get activation unless i go to lock up the brakes.
by navigator » Fri Jun 10, 2016 5:27 pm
Mike, were the Duratracs the tires that were so soft they actually slip on the rim and are hard to balance
by PROSPHOTO » Fri Jun 10, 2016 7:08 pm
I don't know; got them as a package deal on the wheels from discount tire direct. They are very soft tires definitely!
-Mike
PROSPHOTO
