New Disconnect Supplier
by HARDTRAILZ » Fri Jun 05, 2015 11:52 am
May be old news but I had not seen this before
http://www.ebay.com/itm/NEW-Trailblazer ... 60&vxp=mtr
Reason: Split from Chat thread
by navigator » Mon Jun 08, 2015 1:31 pm
HARDTRAILZ wrote:May be old news but I had not seen this before
Nice find Kyle. It looks similar to the direction a poster here was headed.
viewtopic.php?f=32&t=4760&hilit=disconnect+new+design&start=40
by Trail X » Mon Jun 08, 2015 1:49 pm
I haven't seen this before, so I split the posts out into its own topic. Here's a quote from the ebay listing about what they changed to make it "better than OEM".
THIS NEW UNIT HAS BEEN IMPROVED OVER THE ORIGINAL OEM UNIT. WE HAVE REENGINEERED THIS NEW 4WD FRONT AXLE ACTUATOR AND DISCONNECT ASSEMBLY. WE HAVE IDENTIFIED THE INTERNAL PROBLEM AREAS AND USED A DIFFERENT ALLOY STEEL FOR THE INTERNAL GEARS AND FITTED THE INTERNAL HOUSINGS WITH PREMIUM QUALITY GERMAN PRECISION MADE INA NEEDLE BEARINGS WITH UNIQUE TOLERANCES TO HOLD GREASE LONGER AND SUSTAIN HIGHER TEMPERATURES. WE HAVE ALSO USED A SUPERIOR SHELL GADUS S2 V220 SYNTHETIC LUBRICANT THAT WILL WITHSTAND FAR MORE ABUSE THAN THE OEM LUBRICANT. ALSO INSTALLED ARE SPECIAL MACHINE GRADE 12.9 ALLOY SOCKET HEAD CAP BOLTS TO REDUCE FLEXING OF THE ALUMINUM HOUSING. THIS IS THE UNIT THAT ENGAGES AND DISENGAGES YOUR 4 WHEEL DRIVE. IT MOUNTS TO THE OIL PAN.
Interesting.
by HARDTRAILZ » Fri Jun 19, 2015 11:22 am
by Eredin » Fri Jun 19, 2015 2:12 pm
HARDTRAILZ wrote:The AWD version for CHEAPER
http://www.ebay.com/itm/Trailblazer-Env ... railblazer
That looks pretty legit. :hmm:
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
by Jrgunn5150 » Wed Jul 08, 2015 8:54 pm
Awesome, I need one, was just going to order the Dorman off Amazon for 380...
Ill be the Guinea pig here, and thanks Kyle for the referral!
by ErikSS » Wed Jul 08, 2015 10:58 pm
I added both to my Watch List. MUCH less expensive than the unit I went with. It also looks better IMO. If I stumble into some cash I could pick one up as a back up. Nice find Kyle!
by Jrgunn5150 » Wed Jul 08, 2015 11:12 pm
Hopefully I have it Saturday, I want to get this changed ASAP, my CV is flopping about now...
I'm really skeptical, but I'll Crack it open and take pics etc.
by Jrgunn5150 » Thu Jul 16, 2015 1:50 am
Well it's here,
by Pitch22 » Wed Dec 23, 2015 1:42 am
Would anyone recommened this brand? I need a new disconect and like the price of this one a lot but I'm not sure if I should trust an ebay brand. Jrgunn5150 I see youre running this, hows quality compared to a brand like Dorman? Also what kind of warranty does this have? Thanks
Pitch22
by Jrgunn5150 » Wed Dec 23, 2015 8:58 am
I have nothing to compare it to, it's the only one I've used lol. It was well put together, used good hardware, and was well machined. It does, ACTUALLY have the AWD sleeve in it, since I saw someone, maybe DirtyBacon, post that his aftermarket one that was supposed to be an AWD sleeve, still had the splined disconnect in it.
All I can say is, mine has been in since July, has run about 15,000 miles, has been wheeling regularly, and is functioning properly currently.
Thanks to El Nino, I haven't had much snow to really work it out, but I would recommend the brand, and have several times, to anyone.
by dvanbramer88 » Sat Feb 13, 2016 11:29 am
I installed one of these in my parents trailblazer. 4x4 engagement/function has been reliable. Seems to be a quality piece and a good value.
by Jrgunn5150 » Sun Feb 14, 2016 12:32 am
Mine is also still working well.
by DirtyBacon04 » Tue Feb 16, 2016 8:28 pm
fuuuck.. I went to order one today and they are out of stock...
by Jrgunn5150 » Tue Feb 16, 2016 10:16 pm
The link Kyle posted up top say's they have 10 available?
by DirtyBacon04 » Tue Feb 16, 2016 11:34 pm
Jrgunn5150 wrote:The link Kyle posted up top say's they have 10 available?
you're referring to the 4WD link. I'm wanting the AWD
by Jrgunn5150 » Wed Feb 17, 2016 12:41 am
Different seller, looks just like mine from US Powertrain though,
http://www.ebay.com/itm/Bravada-Trailbl ... 1c4ace1232
by Rickalicka18 » Wed Feb 17, 2016 8:29 am
Might of been touched upon already but is there any benefit of the awd disconnects over the 4wd disconnects? Or vice versa? Need to replace my disconnect soon, but was wondering if one was better than the other. Other than the price...
Rickalicka18
by HARDTRAILZ » Wed Feb 17, 2016 9:11 am
The slug vs moving parts. Discussed many times. May lose a minimal mpg but you do not have any failure risk of a shift fork.
by Rickalicka18 » Wed Feb 17, 2016 1:21 pm
Ahh, so the 4wd just has a little better mpg, but the awd last longer. Thankyou. Might be another dumb question, but if I were to install the awd would I still be able to switch between 2 and 4wd or Is it just in awd all the time.
Rickalicka18
