camshaft timing solenoid
by TangoBravo » Wed Mar 07, 2012 6:05 pm
Has anyone replaced one of these? seems simple enough but if you ran into trouble or picked up some tricks could you let me know?
TangoBravo
by The Roadie » Thu Mar 08, 2012 10:23 am
You have to get the power steering pump out of the way, so if you haven't changed your serpentine belt it's a good time to do that also. Only one bolt holds the CPAS in. Dorman makes an aftermarket replacement, but experiences posted on trailvoy and GMTN have not been all positive. Use AC Delco.
by TangoBravo » Fri Mar 09, 2012 12:03 am
The Roadie wrote:You have to get the power steering pump out of the way, so if you haven't changed your serpentine belt it's a good time to do that also. Only one bolt holds the CPAS in. Dorman makes an aftermarket replacement, but experiences posted on trailvoy and GMTN have not been all positive. Use AC Delco.
I don't know what brand mine is, I got it from NAPA and thats all it says anywhere. The part its self has no markings on it at all. Thank you for the tips
TangoBravo
