dvanbramer88 wrote:Update, My neighbor concluded it is not a timing issue, he got the distributor more correct than i did. It is still running rough. He said it's running on 7 or less cylinders. Tomorrow I'm going to figure out which one(s). Ya take your old fashioned circuit checker (the screw driver style with a light bulb in the handle and a ground wire), clip the wire to metal, and stab each spark plug boot with it. Normally, the truck will run worse because you are grounding out a cylinder. When you stab the bad cylinder's plug wire, the truck won't run any worse. His and my guess is i cracked/damaged a spark plug while working on/handling the heads. Just gotta figure out which one.
I do the same basic thing, but just pull each plug wire off the plug one at a time. The one that makes no difference is the bad one. Can get a little shocking though..
