Has anyone installed a larger fuel tank?
by chevycrew » Fri Mar 11, 2011 12:13 pm
Has anyone thought of using a second tank in the spare tire location? Since larger tires won't fit, it would be available space.
by bgwolfpack » Fri Mar 11, 2011 12:22 pm
by HARDTRAILZ » Fri Mar 11, 2011 12:23 pm
Thought yes. Able to justify the cost for a once a year usage...no. cheaper to carry a 5 gal can on big trips.
by mikepeters1983 » Fri Mar 11, 2011 12:26 pm
chevycrew wrote:Has anyone thought of using a second tank in the spare tire location? Since larger tires won't fit, it would be available space.
That is going to be what I am going to do when I get the funds. I am thinking that a Jeep YJ fuel tank with armor would work perfect for that spot. But funds plus me still being in Afghan right now makes it hard to look at and or take measurements.
mikepeters1983
Vehicle: GMC Envoy XUV
DriveTrain: 2WD w/ G80
by The Roadie » Fri Mar 11, 2011 1:48 pm
I'm going to put in a 20 gallon polyethylene water tank (with armor) where the spare used to be. Someday.
by chevycrew » Fri Mar 11, 2011 3:46 pm
Check out the 4 door s10 blazer. tanks. Its what I use behind the rear axle in toyotas. They measure something like 34 x 22 x 10.
by bartonmd » Fri Mar 11, 2011 4:02 pm
chevycrew wrote:Check out the 4 door s10 blazer. tanks. Its what I use behind the rear axle in toyotas. They measure something like 34 x 22 x 10.
Just like the tank in the '89 2-door S-10 Blazer that I had... Get it loaded with a pump and everything (used to transfer to main fuel tank, as the later TBs are returnless fuel systems) brand new, for like $175, last I bought one...
by chevycrew » Fri Mar 11, 2011 5:22 pm
Oops, I meant 2 door or early 4 door.
Yep that's exactly what I was thinking!
by Diacom » Sun Mar 13, 2011 12:51 am
Interesting idea using a S-10 blazer tank, I just happen to have one ready to haul to the junk yard, guess I need to remove a few more parts before I let it go. It is a 20gal tank though, but might be worth playing with.
