by mason10198 » Mon Apr 04, 2016 7:11 pm
I THOUGHT I was replacing engine mounts, front crank seal and front diff pinion seal, but ended up tearing most of it down for nothing. I got the engine mounts done, but turns out the crank seal isn't leaking, it was just a loose head cover bolt, and the pinion seal isn't something my dad wants me to do alone.
I thought the fan was going to be a total //// to get out involving a bunch of special tools and crap, but I saw a YouTube video where a guy said all you gotta do is have someone hold a big pair of wide mouth pliers on two of the bolt heads on the pulley while you pop the fan nut loose with a big adjustable wrench. I can't believe how easy it was.
It's still in pieces in the garage, hopefully I'll have it back together in the next two days. Should have known better than to follow GM instructions... Pulled way more off than I had to.
Sent from Tapatalk
| Mason | | | |
