by KingBird » Mon Oct 19, 2015 11:09 am
Chasing down an issue. Since the engine swap ('06 into '02), I've had a slight stumble at low throttle input. Now, only once the engine is warmed up, it will stall at idle. The TB is clean, and I've even switched it out with the old TB just to be sure. Spark plugs are good, coil packs are correct and fine, no CEL but I DO have a code for O2 sensor bank one sensor 2, which is reasonable since I have a gutted cat.
Cam actuator solenoid has been changed with known good.
Damn thing is starting to piss me off, it ONLY does it when hot and only at low /no throttle (less than 20% throttle input according to Torque app on my phone). Sunday, it started stalling at stop signs/intersections.
Do any of you think that getting the computer reprogrammed would solve it? I only ask because it's progressively gotten worse. I don't want to spend $300+ and still have the issue afterward...
