by Shdwdrgn » Thu Aug 14, 2014 12:52 am
Made progress on my inverter. Picked up some 6ga wire on Monday and got the rest of the ring terminals yesterday to finish off the wires, but had no luck at the parts store finding an 80A breaker (they jump from 50A to 100A with nothing in between). I'm not too happy with the ground connection under the bolt I chose, so I might make up another wire to a different point that has better contact with the body.
Tonight I decided to give it a test, so I hooked up the positive cable and started trying various power tools while keeping one hand on the main power wire into the fuse box, checking for heat. I tried everything up to my high-torque 1/2" drill which pulls up to 8A (although I did not have it under any load), and never had the wire get warm nor the fan turn on. I have a handheld belt sander that pulls 5.3A, I think tomorrow I'll give it a test under load. However my main considerations were fairly low loads like battery chargers, and I don't see there being any problems with this unit. The plexiglass mounting base was solid enough to plug in grounded cords with one hand, so overall I'm happy with how this turned out. If I find a breaker that works with ring terminals, I can add that in later, but now I have a source of emergency power if needed.
--which means I'll probably never need it again--
