by Shdwdrgn » Mon Jul 28, 2014 4:53 pm
Shdwdrgn
Contributing Author
by chevycrew » Mon Aug 04, 2014 5:32 pm
I really listed mine for sale on facebook. I'm not sure what I want to do, kinda joking, kinda serious,
If someone showed up on my doorstep with a check for 12k, they can have it.
by Shdwdrgn » Mon Aug 04, 2014 6:22 pm
I think I finally figured out the mounting points for the caps on the new light bar I'm building. One of those things, I was going about it all wrong, where a simple solution is also more solid. I have a lot of PVC split in half, wish there was an easy way to get the splits squared up, but the best I can come up with there is just using a hand belt sander and a straightedge. Once I have my caps in place, then its just a matter of cutting slots for the lights to shine through. I think the only thing questionable about this project is whether my radar detector will still work after I rewire the display to a long cable.
Shdwdrgn
Contributing Author
by chevycrew » Tue Aug 05, 2014 1:12 am
I can see a table saw helpful for splitting pvc.
by Trail X » Tue Aug 05, 2014 10:26 am
I finally put in my front diff (it didn't explode this time), and tightened up my exhaust bolts... I need to figure out some way of keeping them from loosening up next time, because I'm pretty sure they will loosen again.
by Moots1288 » Tue Aug 05, 2014 12:56 pm
The manifold bolts??
by Trail X » Tue Aug 05, 2014 1:18 pm
Yeah, I used replacement Dorman bolts, no patch lock on them. Not sure if I necessarily want patch though, because I don't want to go through what I did before with a broken bolt.
Was thinking of a lock washer of some sort, or maybe a Belleville washer set.
by Wahugg » Tue Aug 05, 2014 2:57 pm
Wahugg
by Moots1288 » Tue Aug 05, 2014 3:31 pm
That seems like an odd question. Are you looking to run with no fluid?
by Moots1288 » Tue Aug 05, 2014 3:33 pm
by Wahugg » Tue Aug 05, 2014 4:07 pm
Wahugg
by Trail X » Tue Aug 05, 2014 10:36 pm
by Wahugg » Tue Aug 05, 2014 11:48 pm
2 miles?!
That surprises me! I imagine a bearing would last longer than two miles without oil, but then again as you said this was a fresh install with no residual oil and you do have an AWD sleeve so all your internals were moving. In my scenerio, I was probably just spinning the spider gears and maybe the intermediate shaft due to my lack of an AWD sleeve.
I'm sorry to hear this happened to you James but it does make for an interesting mistake none the less.
-Wallace
Wahugg
by Moots1288 » Wed Aug 06, 2014 12:29 am
by ErikSS » Wed Aug 06, 2014 7:20 am
The pinion bearing siezed.... So he thinks....
James, is there a way to be more sure what happened in there? I'm also surprised how fast it broke without fluid.
by Trail X » Wed Aug 06, 2014 9:03 am
Yeah, I'm amazed it only lasted two miles too.
All I really know at this point is that the pinion will not spin at all, and the ring gear now seems to be toothless.
I plan to open it all up and take some pictures and try to figure out what failed first.
by dvanbramer88 » Wed Aug 06, 2014 9:27 am
James, the lock washers on my manifold bolts are working well. I'm around 1500 miles since the install and everything seems good to go.
by Wahugg » Wed Aug 06, 2014 9:31 am
Wahugg
by Moots1288 » Wed Aug 06, 2014 9:34 am
by Trail X » Wed Aug 06, 2014 9:50 am
