by HARDTRAILZ » Fri Jan 31, 2014 11:34 pm
Seen a few Nitro gear failures in Jeeps recently. My buddy had his rear explode in his TJ, swears they just broke, but he is known to be rough on stuff. A couple JK guys reported on FB that they had broken teeth recently as well.
by v7guy » Sat Feb 01, 2014 3:30 am
Yeah, I saw a few nitro gears setups fail too, a couple motive, a bunch of Richmond back a year ago or so, I think just about all the different brands of gears have had a rough spot at some point and obviously if you get all crazy I reckon you can break just about everything.
by Wahugg » Sat Feb 01, 2014 1:28 pm
Went ahead and got my kmart special today :finger:
Wahugg
by The Roadie » Sat Feb 01, 2014 1:31 pm
Say, that's that ring lug doing unconnected to the right? It's going to leak out all the charge from that battery if you don't hook it up. :slap:
by Wahugg » Sat Feb 01, 2014 1:54 pm
Letting the computer/ modules reset. I'm hoping the -3 degree weather was the reason why my battery died, but there is a chance a module wasn't going to sleep. There was about a 1-2 week time period between both times my battery died. It would start fine the same day, but the next weekend it would be almost flat again. I'm hoping a full 'reset' might make the computer or module behave correctly if that is the case. But what do I know, your the EE here!
-Wahugg
Wahugg
by mikekey » Sat Feb 01, 2014 2:58 pm
by Aries » Sat Feb 01, 2014 6:01 pm
Aries
by djthumper » Sat Feb 01, 2014 6:19 pm
And this is what you did to your GMT today? :?:
by Moots1288 » Sat Feb 01, 2014 6:39 pm
Washed her up Image
by mikekey » Sat Feb 01, 2014 7:21 pm
Aries I think you meant to post that in the GMT Official Post Whore thread. :poke:
Well, it took a lot of work to make the bracket, and trial and error, but they are mounted. :zombie:
by Moots1288 » Sat Feb 01, 2014 7:48 pm
What the brembos or the 5 lug wheel hub :P
by dvanbramer88 » Sat Feb 01, 2014 7:58 pm
perhaps it's for his Corvette?
Or he's just trolling. Probably just trolling..
by DirtyBacon04 » Sat Feb 01, 2014 8:02 pm
or his GXT thing
by mikekey » Sat Feb 01, 2014 8:12 pm
Trolling, I should of tried GMT, you guys are too smart to notice the 5 lugs.
by DirtyBacon04 » Sat Feb 01, 2014 8:22 pm
by Aries » Sat Feb 01, 2014 9:55 pm
Aries
by djthumper » Sat Feb 01, 2014 11:38 pm
by mikekey » Tue Feb 04, 2014 6:31 pm
Installed a new belt, old one has been on the rig since we bought it.
GRRR! :wallbash: 2 months later and Summit finally mails me the parts I order on Dec 3rd.
So now I guess I have to decide if I want to go through the trouble of installing these after putting most of the front end back together. Well..... I might as well. Guess I'll have to redo my alignment and break out the chalk and string again.
by KE7WOX » Tue Feb 04, 2014 9:41 pm
At least the bushings come pre-installed. Which finally solved my decades old question.
by mikekey » Thu Feb 06, 2014 5:29 pm
:slap:
