by DustinC1989 » Thu Mar 21, 2013 7:44 pm
Cleaned the interior top to bottom and un-flipped my UCA's
DustinC1989
by darring70 » Thu Mar 21, 2013 8:01 pm
DustinC1989 wrote:Cleaned the interior top to bottom and un-flipped my UCA's
NICE, I am buying my front set up and will flip my UCA at the same time of the installation
darring70
by Moots1288 » Thu Mar 21, 2013 8:04 pm
Truck is up and running
by DustinC1989 » Thu Mar 21, 2013 8:07 pm
I un-flipped mine, I flipped them because I had planned to have my lift shortly after doing it... But things have gotten in the way and I won't have the lift for awhile so I put then back to normal.
DustinC1989
by dvanbramer88 » Thu Mar 21, 2013 10:51 pm
Moots1288 wrote:Truck is up and running
I approve this message. :cheers:
by Conner299 » Fri Mar 22, 2013 1:10 pm
Well... Since we had a nice day, I decided to get one of my two Mag-Lites mounted in the truck. Rethinking the mounting placement on the front door, for the second one. These things hold the lights TIGHT. The INT panel likes to pull out and push in a bit as the light is removed or put back. Overall, very happy with the placement on this one.
[url]Image[/url]
[url]Image[/url]
[url]Image[/url]
Conner299
by HARDTRAILZ » Fri Mar 22, 2013 1:20 pm
I have my 6 cell mounted to fuse panel cover under Dr rear seat. One clamp and it never moves. Set it at a height where the bulb end rest on floor for weight support.
Nice placement in the rear I thought about going vertical on rear pillar.
by Conner299 » Fri Mar 22, 2013 1:29 pm
I was thinking about the pillar, but decided against it. With the two mounts, its hard to get a good mount on the curved surfaces. The mounts like it be flat and as even as possible, between the two.
Conner299
by Moots1288 » Fri Mar 22, 2013 5:21 pm
Conner299 wrote:Well... Since we had a nice day, I decided to get one of my two Mag-Lites mounted in the truck. Rethinking the mounting placement on the front door, for the second one. These things hold the lights TIGHT. The INT panel likes to pull out and push in a bit as the light is removed or put back. Overall, very happy with the placement on this one.
[url]Image[/url]
[url]Image[/url]
[url]Image[/url]
I did it the same way.
by mikekey » Fri Mar 22, 2013 5:50 pm
Tires mounted to rims. Is it tomorrow yet? :cheers:
by djthumper » Fri Mar 22, 2013 7:37 pm
mikekey wrote:Tires mounted to rims. Is it tomorrow yet? :cheers:
Very nice! Did you only get the 4?
by DustinC1989 » Fri Mar 22, 2013 7:51 pm
Started my removable rear seat project. Going to be decent out again tomorrow, sure I'll find something else to tinker with.
DustinC1989
by mikekey » Fri Mar 22, 2013 9:18 pm
At the moment yes. I originally bought 5 tires of the Grabbers since we where going on our trip so soon, so I'm debating what to do for our spare as I'm pretty sure they aren't going to fit on the spare rim I have. But at the moment I have no plans to go wheeling or hard on her, so I feel fine without the spare while I work out the kinks in my plan. 8-)
by HARDTRAILZ » Fri Mar 22, 2013 10:04 pm
Used Bfg at in 315 are pretty easy to find since h2 came stock with them. Grab one n a steel wheel. Better than far off mismatched size or going without.
by mikekey » Fri Mar 22, 2013 10:53 pm
HARDTRAILZ wrote:Used Bfg at in 315 are pretty easy to find since h2 came stock with them. Grab one n a steel wheel. Better than far off mismatched size or going without.
That case I might buy more than one spare if I can find some around town.
by darring70 » Sat Mar 23, 2013 3:46 am
Nice, what size are the tires?
darring70
by HARDTRAILZ » Sat Mar 23, 2013 7:47 am
I am taking mine out to party today. Gonna go shoot some trap n maybe have a couple beers .
by JorDaneeKey » Sat Mar 23, 2013 5:48 pm
Not as much as we wanted to. Murphy's law met the rig today. I'm surprised Mikekey is still sane. I was about ready to throw a wrench at her.
JorDaneeKey
by mikekey » Sat Mar 23, 2013 6:00 pm
I installed my massive upper and lower control arms and panhard bar. Taking a break, then making final adjustments in awhile.
by Moots1288 » Sat Mar 23, 2013 6:31 pm
mikekey wrote:I installed my massive upper and lower control arms and panhard bar. Taking a break, then making final adjustments in awhile.
Look good..
