{SOLVED}Lift on, now a clunking sound while going over bumps
by 05ls_soldier » Tue Mar 16, 2010 7:53 pm
Hey Guys, I got my lift set-up done, MarkMC lift, Bilstein HD's all around and 285-70r17 Maxxis Bighorns (pics soon, I promise) And now when I go over big bumps, or even the curb out of my driveway, I get a clunk sound from the rear suspension. I have double checked everything, Its all tight, the spring doesnt move or anything. Could my shocks be bottoming out? Do I need to get the longer sway bar end links? Any opinions would be great, the Mrs. is all mad that the truck sounds "ruined" Thanks!!!
Save the gold, I'm investing in lead!
If guns are outlawed, only outlaws will have guns!
MY BUILD THREAD
05ls_soldier
by Philberto » Tue Mar 16, 2010 8:27 pm
Check the tightness on the shock mount nuts... also, did you make sure to use washers to shim the lower mounts if you used the z71 shocks? Any looseness will cause clunking.
by Gordinho80 » Tue Mar 16, 2010 8:55 pm
Could be bad rear end links... how many miles on the current set?
by 05ls_soldier » Tue Mar 16, 2010 9:16 pm
No, I didn't use the z71 shocks, But I did crawl under there and noticed the spring isolator wasn't all the way on there, recompressed the spring, moved it over, now the cluck is gone! Thank you for responding!
MY BUILD THREAD
05ls_soldier
by irishboy02 » Wed Mar 17, 2010 1:20 am
:o That coulda been bad...good find/fix
2003 GMC Sierra z71
7" FTS lift
irishboy02
