Broken sway bar link
by Anthony Hernandez » Tue Mar 11, 2014 9:52 am
I was swapping my fsbl out and the thing doesn't have a spot for holding it with a wrench to keep it from turning while you are tryin to free it up to remove it... I cut off the boot thinkin it might be underneath it... My new ones have it as well as grease fittings, ( the other one didn't) any one know of a way to "hold" it from spinning to remove the bolt?
by navigator » Tue Mar 11, 2014 10:08 am
there should be a large allen head inside the bolt itself.
You can hold the bolt with the a large allen wrench while turning with a wrench.
by Wahugg » Tue Mar 11, 2014 10:28 am
Just cut it off with a sawzall
-Wahugg
Wahugg
by Cable810 » Tue Mar 11, 2014 2:37 pm
As Chris said Should be an Allen key hole. The absolute gayest thing to ever think of. I had to hack mine off when doing my axle swap.
by Anthony Hernandez » Wed Mar 12, 2014 2:48 pm
Roger...i grabbed some cutting wheels just in case but ima try to use an Allen wrench thanks..
by The Roadie » Wed Mar 12, 2014 4:07 pm
If you're trying to use the allen hex recess, start spraying it with PB Blaster a couple of days in advance. The basic insane design of these links is the hex recess makes the threaded part weaker with a thinner wall. And the amount of torque you can develop with the allen wrench before it spins in the recess is tiny. You can attempt to strengthen the threaded stud wall by putting a nut on it to increase the effective wall thickness, but why bother? You're going to throw it away later. Installing the link using the hex recess is usually not necessary, since the nut snugs up nicely without your having to hold the stud. Another trick to make sure they don't get noisy later is to severely OVERtorque the nuts you put on, and use loctite.
by Anthony Hernandez » Wed Mar 12, 2014 5:38 pm
I've actually recently had the noise problem with another vehicle I replaced them on I'll have to try that..... Blue or red locktite ? :salut:
by The Roadie » Wed Mar 12, 2014 5:55 pm
Anthony Hernandez wrote:.... Blue or red locktite ? :salut:
by Bcchevy » Mon Mar 17, 2014 3:08 pm
Really think a thumbs up option should be added
Cool pic roadie
Bcchevy
by The Roadie » Mon Mar 17, 2014 4:53 pm
Bcchevy wrote:Cool pic roadie
Made it myself at the Memegenerator site. Easier than my usual Photoshop job. I just naturally write funny copy. :friday:
