I still have the AC Delco which was put on Before I bought the Traiblazer. I've got an ABS/parking brake light which I've too lazy to fix but other than that no codes that I'm aware of. I've added nothing. I've got my Spare tire and recovery equipment and that's it. The Roadie wrote:Research, plan your mods, fund the plan, then GO DO THEM. THEN WHEEL IT.
Cable810 wrote:if it turns out to be bad gas NEVER EVER get gas from speedway.
HARDTRAILZ wrote:Cable810 wrote:if it turns out to be bad gas NEVER EVER get gas from speedway.
How about finding out if this is even true before posting something this ignorant? I run about 40 gallons A WEEK of Speedway fuel with no issue at all.
HARDTRAILZ wrote:Mike...he does not even know what his MPG is...present or past.
Cable810 wrote:Yep lol I just fill up and go except when I go on LONG trips over 130 miles which is very rare then will I calculate. I WAS NOT saying that the Gas at Speedway was bad It was a thought. My Alignment is still good. Call me stupid and delete this thread for all I care.
. Why don't you do some real calculations and see what your mpg is if you are concerned. You do not need long trips, just a record of miles and gallons. Simple calculation and you would have something worth a shit rather than this drivel you fed us. Not sure what you were hoping for, but we can't help you without real info. It takes a little effort, but not much to get the info needed. Depending on how far and often you drive you could rack up a couple tanks or say 500 miles in a pretty short time and we obviously are willing to help you.
I cleaned the Throttle Body last year...
