manifold studs broke off in head!!!
by tarsh » Fri Aug 16, 2013 8:34 am
What's the easiest possable way to get them out. The very front one broke and the 2 back ones broke. Any ideas? Or a high heat gasket sealer or something? Anything would help :)
Take the path less traveled
tarsh
Name: Nathan Schroeder
by jonbo2002 » Fri Aug 16, 2013 9:32 am
easyout would be my first choice
jonbo2002
by Moots1288 » Fri Aug 16, 2013 9:36 am
jonbo2002 wrote:easyout would be my first choice
How much of the stud is sticking out? Can you try grab it with a vise grip?
by The Roadie » Fri Aug 16, 2013 9:39 am
There are tools, but unless some stud is exposed, they all involve drilling a pilot hole. For rearward ones, this will require a smallish right angle drill. Patience and repeated application of PB Blaster is mandatory.
by Moots1288 » Fri Aug 16, 2013 10:01 am
The Roadie wrote:There are tools, but unless some stud is exposed, they all involve drilling a pilot hole. For rearward ones, this will require a smallish right angle drill. Patience and repeated application of PB Blaster is mandatory.
X2
by tarsh » Fri Aug 16, 2013 10:27 am
Only one stud it sticking out. Broke at the head. The other 3 are flush with block.
tarsh
by NC_IslandRunner » Fri Aug 16, 2013 1:24 pm
X2
X3
Had to use one on my buddies honda just to get the rotors off.
