If yours is like mine, it will come and go.
Does anyone else with the phantom misfire have a scangauge? If so, when you watch the AFR reading, is it static at 14.6? I'm beginning to suspect my O2 sensors - because my AFR metric never varies from 14.6. But I'm not sure if maybe the scaugauge is just erroneously reading a set value in the PCM.
But I'm also worried that if I change out my O2 sensors that I'll end up having an SAI issue - because I haven't heard the hairdrier in years. Might be better off just keeping the old O2 sensors...
