c bausch wrote:But I didn't mention that first few seconds maybe 6 seconds I can see the exhaust almost sounds like its misfireing while the air system is doing its cycles then after that it runs fine, I guess my question is if my a.I.r system pump,valve is bad would it cause misfireing on first few seconds on start up?
My 07 sounds like that with the pump running, I would assume its from the extra air being pushed through the exhaust. After the pump spins down, it stops and the exhaust is normal sounding. If you don't have any lights I wouldn't worry about it.
My 02 doesn't have the air system, and sounds just like the 07 after the initial start up.
I don't know if the information made it to gmtnation or not, that may be a better resource for searching, although there is a lot of common members here.
