Possible Xfer Case Seal leak... uh oh.
by DirtyBacon04 » Tue Jan 31, 2012 4:44 pm
yea, so i layed under my truck to replace the fuel filter when I noticed out glossy and black the frame was... I spotted xfer case fluid drips on the bottom of the case. I belive it is the front seal. But to confirm, I just wiped it all up and am going to take it for a spin to get a better hone in on the discrepency. From reading previous threads, i hear replacing this seal is a PITA :wallbash: !! But I'm looking forward to it, none the less. Better to find it now than out in the desert!
by navigator » Tue Jan 31, 2012 5:07 pm
how low is the fluid?
by v7guy » Wed Feb 01, 2012 10:19 am
:need pics:
by bartonmd » Wed Feb 01, 2012 10:39 am
If it's the rear output seal, that's not a huge deal... If it's the front seal, or the seal between the halves of the case, that is a bigger job, and unless it's REALLY bad, you might as well just keep adding fluid...
by DirtyBacon04 » Wed Feb 01, 2012 12:47 pm
bartonmd wrote:If it's the rear output seal, that's not a huge deal... If it's the front seal, or the seal between the halves of the case, that is a bigger job, and unless it's REALLY bad, you might as well just keep adding fluid...
Thats a good idea. Are the 2 output seals the same p/n?
by fishsticks » Wed Feb 01, 2012 1:11 pm
by DirtyBacon04 » Wed Feb 01, 2012 1:21 pm
is that a 'yes' there Donny?
by fishsticks » Wed Feb 01, 2012 1:47 pm
Front seal is different. GM PN 88935670. I don't have the SKF PN off hand, but they make it.
