Ok after searching my thought is that I need a new fan clutch but wanted to run it past you guys before I start ordering parts.
Symptoms:
Fan has been roaring most of this summer on hot days at start up, obviously needs a new clutch but last time I was able to go almost a year without problems before replacing it, it would roar until I hit 20-30 mph and turn off and run fine, doing the same thing this time. Also had and intermittent SES last time, ended up being a bad thermostat which was replaced in fall 2009. No codes this time. I also flushed the coolant at the same time.
Thursday: Drove to the top of a paved canyon at very slow speeds 25ish MPH on a steep incline for roughly 25-30 min. When I parked at the top it started boiling w/in 2 min of parking. Turned the truck on and held the RPMs around 2k, cooled right off let it idle for 3-4 min and had no problems.
Friday: Drove 15 miles city, parked and noticed the engine temps rising. Got it cooled down again, no boiling over this time. 30 min later made a quick trip to the corner gas station, A/C was blowing hot air and engine temps spiking again.
When I got back home here is what I checked:
1: Felt the AC tank, it was hot.
2: AC and Fan fuses, both were good.
3: Checked the radiator for obstructions and other than some bugs it looks clean.
4: Hooked my gauge up and the R134 is slightly overcharged at idle. (Normal)
5: AC pump is cycling, I can hear it click and the RPMs would drop slightly.
6: Checked the oil, didn't see any water on the dipstick or bubbles in the oil.
7: Hooked up my scan tool and didn't find any stored codes.
After I pulled and checked the fuses I restarted the truck to check the R134 pressure and the AC was working fine again. I haven't driven it yet since then.
I know these trucks have the safety shutoff on the AC for overheating protection, so I am assuming that is what happened there.
With no SES light and no stored codes I am wanting opinions before I start shot gunning parts at it.
Fan Clutch, Rad cap, thermostat are my next options, in that order.
TIA.
