Mooseknuckle wrote:Ok I have a whining noise. When I turn the AC on it disappears turn off the AC it's whining again.
Saxis wrote:Mooseknuckle wrote:Ok I have a whining noise. When I turn the AC on it disappears turn off the AC it's whining again.
Kick the wife out! Obviously she can't handle the heat....
Regulator1175 wrote:The AC compressor is a bitch to replace. I have had to replace mine twice and there is not an easy way to get it out.
janesy86 wrote:Regulator1175 wrote:The AC compressor is a bitch to replace. I have had to replace mine twice and there is not an easy way to get it out.
Damn, that's not what I like to hear... I was just about to pick a used one listed on CL for relatively cheap. It's been way too damn hot here, and I do a lot of driving for work, and very often sit around in my truck on sites, so the heat is getting to me... Otherwise I'd not bother replacing such an expensive item.
Regulator1175 wrote:I am glad to hear that it all worked out well for you. I couldn't get my fan off, hence the huge PITA for me when I did mine. Now that you have done it can you imagine trying to snake that up and out of the top of the engine compartment?
dvanbramer88 wrote:Regulator1175 wrote:I am glad to hear that it all worked out well for you. I couldn't get my fan off, hence the huge PITA for me when I did mine. Now that you have done it can you imagine trying to snake that up and out of the top of the engine compartment?
You need what is called a 2 pin spreader to hold the engine from turning while you loosen the fan.
