Radiator spiking
by Hpimichael02 » Fri Apr 08, 2011 7:09 pm
Hey guys so today driving home my efan is on and working and blowing the right direction , and it was goin to 215-225 while driving and in a little bit of traffic , any ideas I think my radiator cap is goin bad cause this be it ?
Hpimichael02
by Trail X » Fri Apr 08, 2011 7:45 pm
Is that by scangauge or by dash gauge?
by Hpimichael02 » Fri Apr 08, 2011 8:27 pm
Dash gauge , but the engine it self was much hotter than normal
Hpimichael02
by chevycrew » Sat Apr 09, 2011 9:34 am
radiator cap or thermostat.
I have the opposite problem. Mine wont go above 175 on the dash gauge (heater sucks because of this), full fluid, ect, guess I get to add a thermostat to the list.
Anyone know if the factory thermostats are fail safe? or commonly stick in the open position?
by The Roadie » Sat Apr 09, 2011 10:16 am
I6 thermostats generally fail slightly open, the coolant temp stays low, and it throws a P0128 code. Many folks change the sensor instead of the thermostat, but statistically, after 6 years on the other site, I think 90% of the reports are solved by the thermostat only.
V8's often run hot if they haven't been burped, and they added a bleed valve at the top of the piping just for that the I6 cooling systems don't need.
by Trail X » Sat Apr 09, 2011 12:28 pm
In my experience, the dash gauge is set to read lower than actual temps to keep people from being overly alarmist. So 225 probably means 230 0r 235 in reality. Try out the cap first, simple easy first attempt. I doubt it's the thermostat.
Steve, I'd bet it's the thermostat, sounds very similar to when mine went out. PITA to change.
by chevycrew » Sat Apr 09, 2011 2:50 pm
Yay! Ive had it a week and radiator and thermostat are both on the list...
But the peace of mind of new parts will be a plus.
by Hpimichael02 » Wed Apr 20, 2011 6:52 pm
Well my truck still over heats a little, I went to feel the air flow through the radi and it's not as strong as it was in the cold weather would the thicker air pose an issue??
Hpimichael02
by bgwolfpack » Wed Apr 20, 2011 7:18 pm
Hpimichael02 wrote:Well my truck still over heats a little, I went to feel the air flow through the radi and it's not as strong as it was in the cold weather would the thicker air pose an issue??
Did you change the cap or the thermostat? If you did and this is still the problem, you may need to check the sending unit for the e-fan and make sure enough water is in the system. IMO :coffee:
by djthumper » Wed Apr 20, 2011 7:34 pm
What troubleshooting steps have you tried?
by Trail X » Wed Apr 20, 2011 8:46 pm
Are you sure the fan was commanded to the same speed? The air temperature (which I assume is what you mean by thicker) shouldn't affect airflow volume.
by Hpimichael02 » Thu Apr 21, 2011 5:41 am
It's a hardwired efan so it's always on , and changed the cap but not the thermostat , before I do that ima remount the fan to actually on the radiator instead of how it is now,
Hpimichael02
by DJones » Sat Apr 23, 2011 9:54 pm
I have an e-fan and a couple of weeks ago my temperature was reading about 220 (as per scangauge) because the temperature probe fell out. Nobody has explained to me the e-fan/thermostat connection. If the thermostat went bad how would I know? The temperature is at a fixed setting.
David
DJones
by Trail X » Sun Apr 24, 2011 12:28 am
DJones wrote:I have an e-fan and a couple of weeks ago my temperature was reading about 220 (as per scangauge) because the temperature probe fell out. Nobody has explained to me the e-fan/thermostat connection. If the thermostat went bad how would I know? The temperature is at a fixed setting.
If your thermostat failed open, your temps would never get to 200, unless you were sitting still for a really long period of time.
by Hpimichael02 » Sun Apr 24, 2011 1:03 pm
thanks for all your input but i found the issue- the issue was the overflow box/ expansion box was completely empty no fluid in there - filled it and the heating issue went away
Hpimichael02
by Zero » Fri Apr 29, 2011 5:35 am
This sounds odd. Isn't that box just an overflow? Could someone please explain how the system works, and why this may have fixed his issue.
Is it a simple matter of pressure or vacume for the cooling system?
by bartonmd » Fri Apr 29, 2011 8:19 am
Zero wrote:This sounds odd. Isn't that box just an overflow? Could someone please explain how the system works, and why this may have fixed his issue.
Yes, the burp bottle is just an overflow that keeps the radiator at full capacity, and keeps it from sucking air in (Dexcool doesn't like air in the system, AT ALL)... If filling the burp bottle solved the problem, the radiator was probably 1/2 empty...
by Zero » Fri Apr 29, 2011 3:16 pm
Just checked mine, and it's empty. Hahaha. I'm due for a full flush sometime soon anyways. And I think my thermostat is stuck partially open. Cause I almost never see water temp any higher than 92c, more often it's around 88-89c
by soldier32mp » Fri May 25, 2012 10:56 pm
LOL mine did the samething and the that was the last thing I looked yep almost bone dry ha ha ha the simplist things we overlook..
soldier32mp
