by HARDTRAILZ » Thu Mar 24, 2011 10:05 am
I have been chasing a sound for a couple weeks now in the drivetrain of my truck. It is hard to explain and it is baffling me. I will share what I have done and tried and maybe someone can help shed some light.
The sound is like rocks in a can or a metal tapping, but it is not always there. Some days it is all the time I drive and others occasional or not at all. Cant find a driver inducing action to force it to happen everything. It has gotten progressively worse. It is however induced by motion and throttle. No noise when the truck is not in drive or reverse. At take off it makes noise while you are on the throttle and the noise will reduce or go away when off the throttle, but will sometimes reappear when braking, but not always.
Sound seems to come from TC, but while out of truck with it on stands and thottle being given it seems to come from driveshaft. But last week i could have sworn it was in the front diff.m Also have had a slight whine/howl when driing for the past few months, but the rear diff looked good when I popped the cover and it it didnt really affect anything. New noise makes me thing failure is coming.
What I have done... I changed TC and diff fluids....no help. I thought it was front diff since when the DR tire is off if io spin the half shaft about once every rotation it seems to grab the front drveshaft and move it a bit. Front diff had light metallic to the fluid but no chunks. TC fluid looked good. Rear was watery, but that makes sense with what I do with the truck.
I still was thinking front diff, so I pulled the dr half shaft and it changed nothing. I did notice that the front draveshaft spin when the truck moves though, but can be stopped by hand and can be freely rotated either way. Currently dr shaft is out and milk cap covering diff hole. A peek in the hole shows no chunks or broken pieces like I expected.
I then thought TC since when I grab the front shaft it seems to move more than I thought and makes some noise, but the neighbors stock TB has same movement and sound when I crawled under it. I put the rearend on jack stands and blocked front tires. Check rear driveshaft, Feels pretty good, maybe a minimal amount of play in the pinion and slightly less play in TC side. I put truck in nuetral and have some one spin tire while I hold driveshaft and the driveshaft seems to want to spin and like the rear is kinda grabbing it, but no noise. Then try starting truck with rear in air and when I rev the motor in D the sound is there. Seems to comes from driveshaft. But also seems that rearend is not acting right, may have been my head. Also seems that more noise from TC than rearend. I try and try to pinpoint sound, but cant so I crack open the poumpkin epecting parts and find nothing, to metal bits, no chipped teeth, just looks like it always has. Spin tires with cover off and diff seems fine. I have pics if anyone wants to see.
So my guesses...u-joints and or rear wheel bearings, but the noise sounds like broken pieces in a diff or something. The transfer case went in and out of 4x4 fine before the issue and again this week including right before tear-down.
Currently it is on jackstands under rear axle and minus the dr half shaft. If you have anything for me to try. Any and all help is appreciated. I talked with Barton and Regulator and ?????...no one knows. Kinda stuck unless I start tossing parts at it.
