Chevy K1500 Electrical Issues
by dvanbramer88 » Wed May 21, 2014 7:40 pm
bartonmd wrote:Did you try it with the plugs out?
It would make sense with what you're seeing, though...
just tried that. Still nothing. I even broke a socket trying to turn the crank.
I'm going to try trans/t-case in neutral next.
by dvanbramer88 » Wed May 21, 2014 8:02 pm
Still won't turn in neutral, and I can push the truck back and forth in neural.
Drained the oil, and it has a milky swirl and is full of metal flake. You can see all the metal with a flashlight, looks like glitter.
by TBYODA » Wed May 21, 2014 8:05 pm
dvanbramer88 wrote:Still won't turn in neutral, and I can push the truck back and forth in neural.
Not good. :(
by Wahugg » Wed May 21, 2014 8:06 pm
Check the oil? Take apart the oil filter? Are there any metal flakes?
Seems bizarre for a motor to just seize like that with no prior symptoms.
-Wahugg
Edit:
Oh no :(
Wahugg
by navigator » Wed May 21, 2014 9:00 pm
do I remember right, isn't that truck pushing 300k?
by dvanbramer88 » Wed May 21, 2014 9:03 pm
276 thousand and some change
by v7guy » Thu May 22, 2014 4:49 am
Strange it let go with no warning at all. Dave, you need to stop screwing around and just get a trailblazer/envoy.
Sorry to hear about the motor man. You gonna take it apart and see what happened?
by dvanbramer88 » Mon May 26, 2014 1:57 pm
Looks like my POS is getting a new heart.
http://www.summitracing.com/parts/nal-1 ... /overview/
My truck has a 2 bolt main L31. Summit has the 4 bolt main L31 for basically the same price as the 2 bolt main version. All new parts/assembly from GM Performance.
Keep in mind that the plan/intention is to get at least 5 more years out of the truck, or even longer. And my goal is not to simply slap a running motor in it and sell the truck.
I figure a used junk yard engine for 800-1000 is a big gamble. And it will probably nickle and dime me at all the wrong times. Head gasket here, intake gasket there, oil leak here. I have all the common stuff for these engines fixed on my engine, I don't want to spend more money to take 3 steps back and have to do all those jobs again at some point, if the motor would even last that long anyway.
Than there is re-manufactured long blocks from Marshall or ATK, which have shitty reputations, and if you read the descriptions, they basically slap new bearings in an old block, and reuse a lot of other parts. After the core and shipping, these options run 1500-1800.
Or I can have a new long block, from GM, slap my freshly overhauled intake manifold on it, my recently tuned up distributor in it, and my fly wheel, and be rolling with a new engine indefinitely for only a few hundred more dollars than questionable reman. I think that is the smart investment.
by TBYODA » Mon May 26, 2014 3:39 pm
dvanbramer88 wrote:Looks like my POS is getting a new heart.
You don't have a POS, and I agree with the investment. BTY I think you should camo your truck. ;)
by navigator » Mon May 26, 2014 4:09 pm
dvanbramer88 wrote:......Keep in mind that the plan/intention is to get at least 5 more years out of the truck, or even longer. And my goal is not to simply slap a running motor in it and sell the truck.
or you could sell your truck for ~$1000 and for about another $1000 buy a TB ;-).
I'm just kidding man, it sounds like a good plan.
