Horriable Gas Mileage affter trip?!?!
by Cable810 » Mon Sep 09, 2013 12:52 pm
3.42 GU6
by bartonmd » Mon Sep 09, 2013 12:56 pm
Cable810 wrote:Alright filled up and it took 10.813 and I drove 214.2 Miles according to OD. So what's the math that will get my actual miles driven ?
miles per gallon = miles/gallon = 214.2/10.813 = 19.8mpg if you odo is correct.
If you actually meant to ask what the odometer error is, you can do a percent difference calculation.
(29.5" - 33")/29.5" = 12% difference low, so take your 19.8mpg and multiply it by 1.12 = 22.1mpg if you have 33" tires.
You're sure your vehicle was at the same angle and you filled not only until it clicked once, but until it was FULL?
ETA, looked at James' post and saw you not only have different size tires, but also went from 3.42 to 4.10, so % difference between (3.42 - 4.10)/3.42 = 20% So multiply 22.1mpg by 0.80 = 17.68mpg
by HARDTRAILZ » Mon Sep 09, 2013 12:58 pm
He also changed gearing and went up in tire size, so the error is not that simple.
by jonbo2002 » Mon Sep 09, 2013 12:59 pm
:Iagree: that and did you fill it completely before you reset your trip?
oh yea and gotta figure out the difference with the gearing change like Kyle said
jonbo2002
by bartonmd » Mon Sep 09, 2013 1:01 pm
HARDTRAILZ wrote:He also changed gearing and went up in tire size, so the error is not that simple.
Yeah, I saw that after I saw James' post, so edited my post.
17mpg aint bad, IMO.
by HARDTRAILZ » Mon Sep 09, 2013 1:04 pm
Those tires are maybe 31.6 not 33...
by HARDTRAILZ » Mon Sep 09, 2013 1:07 pm
16.97.... Not bad at all.
by bartonmd » Mon Sep 09, 2013 1:24 pm
Oh, I didn't see them in the thread and was guessing 33" tires.
by HARDTRAILZ » Mon Sep 09, 2013 1:29 pm
265-70-17 He posted in the posted post with miles and gallons.
by bartonmd » Mon Sep 09, 2013 1:31 pm
Oh, I didn't catch it.
Almost 17mpg with bigger than stock tires and 4.10 gears, though... nothing wrong with that mileage.
by HARDTRAILZ » Mon Sep 09, 2013 1:34 pm
Not at all....
I figured you missed it with all the other stuff going on on your vacation
by Cable810 » Mon Sep 09, 2013 3:08 pm
Ok I filled up completely the last time and reset everything. When it clicks I'll keep going till I start to see some gas coming out. Wow I got worried over nothing :oops: :facepalm:
The formula that Mike posted is the formula to calculate MPG with the oversized tires and different gears?
by bartonmd » Mon Sep 09, 2013 3:21 pm
Yes, except you replace the 33" tire size with whatever yours are. The gear ratio calculation is still correct though.
by Cable810 » Mon Sep 09, 2013 9:34 pm
Ok thanks
by Cable810 » Fri Sep 27, 2013 3:53 pm
Sitting here calculating Mpgs after Drummond. Wanting to make sure I'm getting this right.
(29.5-31.7)/29.5 =0.07 which is 7%? So then 1.07 x mpg = XYmpg x .80 = final Mpg?
by DirtyBacon04 » Fri Sep 27, 2013 6:05 pm
bartonmd wrote:ETA, looked at James' post and saw you not only have different size tires, but also went from 3.42 to 4.10, so % difference between (3.42 - 4.10)/3.42 = 20% So multiply 22.1mpg by 0.80 = 17.68mpg
I'm not very good at math... where did the 0.80 come from? Just the difference from the 20% ?
by djthumper » Fri Sep 27, 2013 6:16 pm
Cable810 wrote:Sitting here calculating Mpgs after Drummond. Wanting to make sure I'm getting this right.
yep that should be correct.
