Power Steering help
by dvanbramer88 » Sat Mar 23, 2013 10:28 am
I pulled my steering gear box to change the pitman arm, and when I got it back together and started the truck, the steering wheel moves back and forth on its own. I stopped the truck, topped off the fluid reservoir again and it kept doing it. I sat in the driveway idling turning the wheel lock to lock and it kept doing it after a few minutes. The lines are not switched. I checked that and they will only go one way.
Basically, if the wheel was straight it wouldn't move itself, but if I started it in one direction or the other it would keeping going by itself until it hit lock.
Does the system just need more time to purge itself?
by dvanbramer88 » Sat Mar 23, 2013 2:56 pm
Resolved. It takes a lot longer than you'd expect for the system to purge itself and start acting normal.
by DirtyBacon04 » Sat Mar 23, 2013 3:13 pm
Glad i could help...
by dvanbramer88 » Sat Mar 23, 2013 3:21 pm
DirtyBacon04 wrote:Glad i could help...
I couldn't of done it without you. :cheers:
by DirtyBacon04 » Sat Mar 23, 2013 3:22 pm
said no one ever... to me
