I noticed last weekend after a long drive some odd behavior from the transmission.
I had the cruise control set about 55MPH (a bit off due to the tires) and on reasonably flat ground it was like it was kicking down then back up a gear repeatedly.
1st question do we all have the 4L60E?
2nd question is it a 4 speed with over drive?
If I get on the gas more it kicks down and its fine, it seems to be only when under relatively light throttle.
Driving at higher speeds 70 + I didn't notice the problem, but I think that may be because of the weight of the vehicle the tires it wasn't getting into OD?
It's only been a week so I'm not sure if its getting worse or staying the same.
Doing some searching and reading maybe something similar to this?
viewtopic.php?f=26&t=3022&hilit=TCC
