Runs like a mis while cold
by TangoBravo » Thu Jul 05, 2012 11:39 am
navigator wrote:you don't have to do a relearn in order to replace the camshaft position sensor but you do for the crank sensor.
If your crank sensor is bad though, I would expect it to throw a code.
When my camshaft position sensor went out it threw a code.
Have you cleaned/replaced the camshaft position actuator? I understand it can contribute to a rough idle at times.
Yes it has a new actuator it was the last thing I replaced before I gave up and had the mechanics look at it. One did say that it threw a cam to crank corralation code but that it was a stored code and the new acctuator should have fixed it but Im not too confident in them.
TangoBravo
