4Wd Disconnect Rebuilt Succesfully, then 4WD Stopped Working
by Trail X » Sat Jan 28, 2012 3:54 pm
The sleeve will be fine because it is supported with both bearings, vs the 1 bearing-per-gear currently.
by arl120384 » Sat Jan 28, 2012 4:13 pm
Ok cool, just to confirm, the 4WD works but I have the service light, and the 4HI light flashes with 2HI steady on the switch. That's normal correct!
Mods - Jettstream HID Fogs/Headlights, MarkMC 2.5" Lift, Quad Tail, 265/65 Tires, Sub/AMP, Custom Stereo/Radio, Bravada Disco Collar Gear Install, Cardone Axles, 1.5" Spacers
Future - Raptor Liner Rockers/Bumpers, LED Exterior/Interior Lighting
arl120384
by The Roadie » Sat Jan 28, 2012 7:05 pm
If the connector is off the front axle actuator, that's normal.
There should be no way for lift stress on the CV shaft to transfer to the gear and to the splined sleeve, as long as the bearings are intact. If the bearings are starting to loosen up and die, you can wiggle the CV shaft and the seal won't be a good seal.
by arl120384 » Sat Jan 28, 2012 7:12 pm
The Roadie wrote:If the connector is off the front axle actuator, that's normal.
Everything should be intact, it's all new! I'll start with the sleeve and go from there.
arl120384
by arl120384 » Wed Feb 01, 2012 8:28 pm
I just got the sleeve today! Does anyone know the direction the sleeve should be in stalled? It appears that one of the collars is slightly wider than the other.
Thanks!
arl120384
by fishsticks » Wed Feb 01, 2012 10:41 pm
Put the end with the tapered splines towards the CV axle.
by arl120384 » Thu Feb 02, 2012 2:55 pm
Thanks! I just finished the re-build again, and let me tell you how smoothly it went, being that it was just rebuilt a few months ago. Axle came right out, and because I greased the disconnect fitting last time, it slid out with little muscle. Sleeve is in, and it works flawlessly. Thanks for everyone's help!
arl120384
