by KE7WOX » Wed Dec 22, 2010 9:32 pm
Mine doesn't have the used fuel. TPMS is only available for certain model years.
My speedo is acting up, it's actually getting worse over time, but it only fails in cold weather or during extended drives, the severity goes from just "zeroing" at 10-40 MPH to moving up but not down (eventually results in me doing "N, D or 3" MPH) to completely freeze. The fuel tank is now starting to not go down after long drives.
I bought a stepper motor off ebay but haven't changed it, I'll probably just get another one for the fuel gauge and then do both. I recently bought a ScanGauge II, mainly because my speedometer is off due to the tires and so that I can get some other real measurements.
If you search the OS, there's quite a bit regarding this same problem, including instructions and part numbers. I also recall reading there that taking it to the dealer to have it fixed will go from $500-1k for a new unit + labor. I paid ~$11 for a stepper motor including shipping.
A temporary fix is to reset the cluster by removing fuse 24 (I believe), which is (on a 2004 I6) in the engine fuse block, on the row closest to the driver side fender, a 10A fuse. Usually removing it for 10 seconds or so will work.
