chevycrew wrote:The problem with the rear links is the angle, for a sas your looking at around 12" of suspension lift. Link suspensions work better with flat arms, with 12" of lift you will have an extreme angle. That's why I ditched the setup, just wouldn't work even with longer links.
chevycrew wrote:Yep, but your still redoing the rear suspension like I said...
chevycrew wrote:Ill measure from my axle centerline, to the bottom of the oil pan. this will give everyone an idea how much is needed. I think I have the bare minimum for front lift with a sas and stock oil pan.
It may be less than I think for total lift.
Measured already... I have 5.5" from the centerline of the front axle, to the lowest point of the stock oil pan drain plug.
18" from ground to center of wheel, and 23.5" to bottom of pan plug.
bartonmd wrote:http://forums.offroadtb.com/viewtopic.php?f=25&t=2389
Kuchar, you finally posted a build thread!!
IMO, that's one of the favorite bumpers that I've done...
